Part Number: MSP-EXP430F5529
Tool/software: TI-RTOS
Following this question, trying to reduce the current consumption of the MSP430F5529, running TI-RTOS.
After trying several things (see below), I still cannot get the current below ~500 uA. Questions:
- Does using TI-RTOS inherently increases current consumption?
- Assuming no interrupts are issued (I've disabled the system tick), and that the MCU is in LPM3, does MCLK frequency still effects current consumption?
Test procedure:
- I've started with a simple example project (gpiointerrupt_MSP_EXP430F5529LP_TI), and converted it for the MSP-EXP4305529
- Disabled SVM H/L, as done in pmm_ex3_lowCurrentConsumption
- In gpiointerrupt.cfg, disabled the Clock module, and configured LPM3 on Idle (see cfg file below)
Configuration script:
/* * Copyright (c) 2015-2016, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* ================ Boot configuration ================ */ var Boot = xdc.useModule('ti.catalog.msp430.init.Boot'); /* ================ Defaults (module) configuration ================ */ var Defaults = xdc.useModule('xdc.runtime.Defaults'); /* * A flag to allow module names to be loaded on the target. Module name * strings are placed in the .const section for debugging purposes. * * Pick one: * - true (default) * Setting this parameter to true will include name strings in the .const * section so that Errors and Asserts are easier to debug. * - false * Setting this parameter to false will reduce footprint in the .const * section. As a result, Error and Assert messages will contain an * "unknown module" prefix instead of the actual module name. */ //Defaults.common$.namedModule = true; Defaults.common$.namedModule = false; /* ================ Error configuration ================ */ var Error = xdc.useModule('xdc.runtime.Error'); /* * This function is called to handle all raised errors, but unlike * Error.raiseHook, this function is responsible for completely handling the * error with an appropriately initialized Error_Block. * * Pick one: * - Error.policyDefault (default) * Calls Error.raiseHook with an initialized Error_Block structure and logs * the error using the module's logger. * - Error.policySpin * Simple alternative that traps on a while(1) loop for minimized target * footprint. * Using Error.policySpin, the Error.raiseHook will NOT called. */ //Error.policyFxn = Error.policyDefault; Error.policyFxn = Error.policySpin; /* * If Error.policyFxn is set to Error.policyDefault, this function is called * whenever an error is raised by the Error module. * * Pick one: * - Error.print (default) * Errors are formatted and output via System_printf() for easier * debugging. * - null * Errors are not formatted or logged. This option reduces code footprint. * - non-null function * Errors invoke custom user function. See the Error module documentation * for more details. */ //Error.raiseHook = Error.print; Error.raiseHook = null; //Error.raiseHook = "&myErrorFxn"; /* * If Error.policyFxn is set to Error.policyDefault, this option applies to the * maximum number of times the Error.raiseHook function can be recursively * invoked. This option limits the possibility of an infinite recursion that * could lead to a stack overflow. * The default value is 16. */ Error.maxDepth = 2; /* ================ Hwi configuration ================ */ var halHwi = xdc.useModule('ti.sysbios.hal.Hwi'); var msp430Hwi = xdc.useModule('ti.sysbios.family.msp430.Hwi'); /* * Checks for Hwi (system) stack overruns while in the Idle loop. * * Pick one: * - true (default) * Checks the top word for system stack overflows during the idle loop and * raises an Error if one is detected. * - false * Disabling the runtime check improves runtime performance and yields a * reduced flash footprint. */ halHwi.checkStackFlag = true; //halHwi.checkStackFlag = false; /* ================ Idle configuration ================ */ var Idle = xdc.useModule('ti.sysbios.knl.Idle'); /* * The Idle module is used to specify a list of functions to be called when no * other tasks are running in the system. * * Functions added here will be run continuously within the idle task. * * Function signature: * Void func(Void); */ //Idle.addFunc("&myIdleFunc"); /* ================ Kernel (SYS/BIOS) configuration ================ */ var BIOS = xdc.useModule('ti.sysbios.BIOS'); /* * Enable asserts in the BIOS library. * * Pick one: * - true (default) * Enables asserts for debugging purposes. * - false * Disables asserts for a reduced code footprint and better performance. */ //BIOS.assertsEnabled = true; BIOS.assertsEnabled = false; /* * Specify default heap size for BIOS. */ BIOS.heapSize = 0; /* * A flag to determine if xdc.runtime sources are to be included in a custom * built BIOS library. * * Pick one: * - false (default) * The pre-built xdc.runtime library is provided by the respective target * used to build the application. * - true * xdc.runtime library sources are to be included in the custom BIOS * library. This option yields the most efficient library in both code * footprint and runtime performance. */ BIOS.includeXdcRuntime = false; //BIOS.includeXdcRuntime = true; /* * The SYS/BIOS runtime is provided in the form of a library that is linked * with the application. Several forms of this library are provided with the * SYS/BIOS product. * * Pick one: * - BIOS.LibType_Custom * Custom built library that is highly optimized for code footprint and * runtime performance. * - BIOS.LibType_Debug * Custom built library that is non-optimized that can be used to * single-step through APIs with a debugger. * */ BIOS.libType = BIOS.LibType_NonInstrumented; //BIOS.libType = BIOS.LibType_Debug; /* * Runtime instance creation enable flag. * * Pick one: * - true (default) * Allows Mod_create() and Mod_delete() to be called at runtime which * requires a default heap for dynamic memory allocation. * - false * Reduces code footprint by disallowing Mod_create() and Mod_delete() to * be called at runtime. Object instances are constructed via * Mod_construct() and destructed via Mod_destruct(). */ BIOS.runtimeCreatesEnabled = true; //BIOS.runtimeCreatesEnabled = false; /* * Enable logs in the BIOS library. * * Pick one: * - true (default) * Enables logs for debugging purposes. * - false * Disables logging for reduced code footprint and improved runtime * performance. */ //BIOS.logsEnabled = true; BIOS.logsEnabled = false; /* ================ Memory configuration ================ */ var Memory = xdc.useModule('xdc.runtime.Memory'); /* * The Memory module itself simply provides a common interface for any * variety of system and application specific memory management policies * implemented by the IHeap modules(Ex. HeapMem, HeapBuf). */ /* ================ Power configuration ================ */ var Power = xdc.useModule('ti.sysbios.family.msp430.Power'); /* * Dynamically change idle mode power settings. * * Pick one: * - true * Allow for dynamic waking of the CPU when returning * from an interrupt at runtime. * - false (default) * Disable run-time checking of this parameter; Yields a * small code saving. */ //Power.allowDynamicMode = true; Power.allowDynamicMode = false; /* * Behavior of the power module when the system enters the idle loop. * * Pick one: * - false (default) * Disables power savings and ignores the power policy function. * - true * The power module inserts a power policy function into the idle loop * where it will take action to save power until the next CPU interrupt * occurs. This option can cause the debugger to be disconnected from the * target. */ Power.idle = true; //Power.idle = true; /* * These options only apply if Power.idle is set to true. The Power.idleMode * parameter determines the system's behavior when it enters the idle loop. * * Pick one: * - Power.LPM0 (default) * - Power.LPM1 * - Power.LPM2 * - Power.LPM3 * - Power.LPM4 * See the Operating Modes section of the respective * MSP430's User Guide for a detailed explanation of these modes. */ //Power.idleMode = Power.LPM0; //Power.idleMode = Power.LPM1; //Power.idleMode = Power.LPM2; //Power.idleMode = Power.LPM3; //Power.idleMode = Power.LPM4; /* ================ Program configuration ================ */ /* * Program.stack is ignored with IAR. Use the project options in * IAR Embedded Workbench to alter the system stack size. */ if (!Program.build.target.$name.match(/iar/)) { /* * Reducing the system stack size (used by ISRs and Swis) to reduce * RAM usage. */ Program.stack = 768; } /* * Uncomment to enable Semihosting for GNU targets to print to the CCS console. * Please read the following TIRTOS Wiki page for more information on Semihosting: * processors.wiki.ti.com/.../TI-RTOS_Examples_SemiHosting */ if (Program.build.target.$name.match(/gnu/)) { //var SemiHost = xdc.useModule('ti.sysbios.rts.gnu.SemiHostSupport'); } /* ================ Semaphore configuration ================ */ var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore'); /* * Enables global support for Task priority pend queuing. * * Pick one: * - true (default) * This allows pending tasks to be serviced based on their task priority. * - false * Pending tasks are services based on first in, first out basis. * * When using BIOS in ROM: * This option must be set to false. */ //Semaphore.supportsPriority = true; Semaphore.supportsPriority = false; /* * Allows for the implicit posting of events through the semaphore, * disable for additional code saving. * * Pick one: * - true * This allows the Semaphore module to post semaphores and events * simultaneously. * - false (default) * Events must be explicitly posted to unblock tasks. * */ //Semaphore.supportsEvents = true; Semaphore.supportsEvents = false; /* ================ Swi configuration ================ */ var Swi = xdc.useModule('ti.sysbios.knl.Swi'); /* * A software interrupt is an object that encapsulates a function to be * executed and a priority. Software interrupts are prioritized, preempt tasks * and are preempted by hardware interrupt service routines. * * This module is included to allow Swi's in a users' application. */ /* ================ System configuration ================ */ var System = xdc.useModule('xdc.runtime.System'); /* * The Abort handler is called when the system exits abnormally. * * Pick one: * - System.abortStd (default) * Call the ANSI C Standard 'abort()' to terminate the application. * - System.abortSpin * A lightweight abort function that loops indefinitely in a while(1) trap * function. * - A custom abort handler * A user-defined function. See the System module documentation for * details. */ //System.abortFxn = System.abortStd; System.abortFxn = System.abortSpin; //System.abortFxn = "&myAbortSystem"; /* * The Exit handler is called when the system exits normally. * * Pick one: * - System.exitStd (default) * Call the ANSI C Standard 'exit()' to terminate the application. * - System.exitSpin * A lightweight exit function that loops indefinitely in a while(1) trap * function. * - A custom exit function * A user-defined function. See the System module documentation for * details. */ //System.exitFxn = System.exitStd; System.exitFxn = System.exitSpin; //System.exitFxn = "&myExitSystem"; /* * Minimize exit handler array in the System module. The System module includes * an array of functions that are registered with System_atexit() which is * called by System_exit(). The default value is 8. */ System.maxAtexitHandlers = 2; /* * The System.SupportProxy defines a low-level implementation of System * functions such as System_printf(), System_flush(), etc. * * Pick one pair: * - SysMin * This module maintains an internal configurable circular buffer that * stores the output until System_flush() is called. * The size of the circular buffer is set via SysMin.bufSize. * - SysCallback * SysCallback allows for user-defined implementations for System APIs. * The SysCallback support proxy has a smaller code footprint and can be * used to supply custom System_printf services. * The default SysCallback functions point to stub functions. See the * SysCallback module's documentation. */ var SysMin = xdc.useModule('xdc.runtime.SysMin'); SysMin.bufSize = 128; System.SupportProxy = SysMin; /* ================ Text configuration ================ */ var Text = xdc.useModule('xdc.runtime.Text'); /* * These strings are placed in the .const section. Setting this parameter to * false will save space in the .const section. Error, Assert and Log messages * will print raw ids and args instead of a formatted message. * * Pick one: * - true (default) * This option loads test string into the .const for easier debugging. * - false * This option reduces the .const footprint. */ //Text.isLoaded = true; Text.isLoaded = false; /* ================ Types configuration ================ */ var Types = xdc.useModule('xdc.runtime.Types'); /* * This module defines basic constants and types used throughout the * xdc.runtime package. */ /* ================ TI-RTOS middleware configuration ================ */ var mwConfig = xdc.useModule('ti.mw.Config'); /* * Include TI-RTOS middleware libraries */ /* ================ TI-RTOS drivers' configuration ================ */ var driversConfig = xdc.useModule('ti.drivers.Config'); /* * Include TI-RTOS drivers * * Pick one: * - driversConfig.LibType_NonInstrumented (default) * Use TI-RTOS drivers library optimized for footprint and performance * without asserts or logs. * - driversConfig.LibType_Instrumented * Use TI-RTOS drivers library for debugging with asserts and logs enabled. */ driversConfig.libType = driversConfig.LibType_NonInstrumented; //driversConfig.libType = driversConfig.LibType_Instrumented; /* ================ Application Specific Instances ================ */ /* Use UARTMon with TI toolchain only */ if (!Program.build.target.$name.match(/iar/)) { var UARTMon = xdc.useModule('ti.tirtos.utils.UARTMon'); } /* * Static Hwi isntance creation, required for MSP430. * * Functions added here will be run given a hardware interrupt occurrs. * * Function signature: * Void func(UArg); */ var hwiParams = new halHwi.Params(); /* Add the GPIO port number as Hwi argument */ hwiParams.arg = 2; halHwi.create(42, "&GPIO_hwiIntFxn", hwiParams); /* Add the GPIO port number as Hwi argument */ hwiParams.arg = 1; halHwi.create(47, "&GPIO_hwiIntFxn", hwiParams); /* * Add UART index number as Hwi argument. * This argument is used to index into the UART peripherial array * declared in the board.c file. */ hwiParams.arg = 0; halHwi.create(46, "&UARTUSCIA_hwiIntFxn", hwiParams); Power.idleMode = Power.LPM3;
