Tool/software: TI-RTOS
Is there a reason you would not declare task variables as static?
I'm guessing when you statically create the thread the variables are static themselves? (I noticed their values persist like they are static, ie. if you increment a counter in a task the value persists).
If you terminate a task, if you declare the variables static will they persist outside the now terminated task?
Are the task variables limited in the task scope only without the static declaration?
Is there anything in the RTOS I should consider for static declarations of variables with TI-RTOS?
I haven't seen much in the SYS-BIOS manual regarding this scope / and existence of variables. Most TI examples don't declare the task variables as a static (some do though I think... 50/50).
