I install the dsp/bios link for omapl138 a sInstallGuide_WinCE_OMAPL138.pdf said step by setp using platform builder ide
there is the error
------ Build started: Project: OMAPL138_AM18X_TI_DEFAULT, Configuration: OMAPL138_AM18X ARMV4I Debug Platform Builder-Specific (_TGTCPU) ------
Starting Build: blddemo -qbsp
BLDDEMO: Generating OS Design Folders
BLDDEMO: Done Generating OS Design Folders
BLDDEMO: Generating OS Design Files to D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\Wince600\OMAPL138_AM18X_ARMV4I\oak
BLDDEMO: Done Generating OS Design Files
CEBUILD: Deleting old build logs
CEBUILD: QUick BSP build and sysgen
Sysgening platform C:\WINCE600\platform\OMAPL138_AM18X
找不到 C:\WINCE600\platform\common\*.bif
CEBUILD: Cleaning platform common clean due to change of project
CEBUILD: Cleaning C:\WINCE600\platform\common\lib
CEBUILD: Cleaning C:\WINCE600\platform\common\target
CEBUILD: Building platform clean due to change of project
CEBUILD: Building -c (C:\WINCE600\platform\common)
BUILD: [Thrd:Sequence:Type ] Message
BUILD: [00:0000000000:ERRORI] Failed to initialize from CECONFIG.H.
BUILD: [00:0000000001:PROGC ] Files Warnings Errors
BUILD: [00:0000000002:PROGC ] Other 0 0 1
BUILD: [00:0000000003:PROGC ]
BUILD: [00:0000000004:PROGC ] Total 0 0 1
BUILD: [00:0000000005:PROGC ]
BUILD: [00:0000000006:PROGC ] 0 Warnings, 1 Errors
BUILD: [00:0000000007:PROGC ] GetSystemTimes (seconds): Idle: 0 Kernel: 0 User: 0
BUILD: [00:0000000008:PROGC ] Elapsed time (seconds): 0
Build for Windows CE (Release 601) (Built on Aug 17 2006 15:18:52)
File names: Build.log Build.wrn Build.err Build.dat
CEFILTER: Failed opening D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\Wince600\OMAPL138_AM18X_ARMV4I\cesysgen\sdk\inc\ceconfig.h
CEBUILD: Building (C:\WINCE600\platform\OMAPL138_AM18X)
BLDDEMO: Building PostSysgen User Projects
BUILD: [00:0000000000:PROGC ] Build started with parameters:
BUILD: [00:0000000001:PROGC ] Build started in directory: D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\StartupApp
BUILD: [00:0000000002:PROGC ] Checking for C:\WINCE600\sdk\bin\i386\srccheck.exe.
BUILD: [00:0000000003:PROGC ] Running passes WCEFILES0, MIDL, MC, ASN, THUNK, PRECOMPHEADER, COMPILE, LIB, LINK, MANAGEDRESX, MANAGEDMOD, MANAGEDDLL, MANAGEDEXE, MANAGEDWIN for ARM.
BUILD: [00:0000000004:PROGC ] Computing include file dependencies:
BUILD: [00:0000000005:PROGC ] Checking for SDK include directory: C:\WINCE600\sdk\CE\inc.
BUILD: [00:0000000006:PROGC ] Scan D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\StartupApp\
BUILD: [00:0000000007:PROGC ] Saving D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\StartupApp\Build.dat.
BUILD: [00:0000000011:PROGC ] Building COMPILE Pass in D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\StartupApp\ directory.
BUILD: [01:0000000026:PROGC ] Resource Compiling .\StartupApp.rc
BUILD: [01:0000000031:PROGC ] Compiling .\StartupApp.cpp
BUILD: [00:0000000035:WARNN ] D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\StartupApp\: Missing source file: D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\Wince600\OMAPL138_AM18X_ARMV4I\cesysgen\sdk\lib\ARMV4I\debug\coredll.lib.
BUILD: [00:0000000039:PROGC ] Building LINK Pass in D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\StartupApp\ directory.
BUILD: [01:0000000054:ERRORE] NMAKE : U1073: don't know how to make 'D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\Wince600\OMAPL138_AM18X_ARMV4I\cesysgen\sdk\lib\ARMV4I\debug\coredll.lib'
BUILD: [01:0000000056:ERRORE] NMAKE.EXE TargetExeFiles -i -c BUILDMSG=Stop. BUILDROOT=D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\StartupApp\ LINKONLY=1 NOPASS0=1 failed - rc = 2
BUILD: [00:0000000057:PROGC ] Files Warnings Errors
BUILD: [00:0000000058:PROGC ] Midl 0 0 0
BUILD: [00:0000000059:PROGC ] Message 0 0 0
BUILD: [00:0000000060:PROGC ] Precomp Header 0 0 0
BUILD: [00:0000000061:PROGC ] Resource 1 0 0
BUILD: [00:0000000062:PROGC ] MASM 0 0 0
BUILD: [00:0000000063:PROGC ] SHASM 0 0 0
BUILD: [00:0000000064:PROGC ] ARMASM 0 0 0
BUILD: [00:0000000065:PROGC ] MIPSASM 0 0 0
BUILD: [00:0000000066:PROGC ] C++ 1 0 0
BUILD: [00:0000000067:PROGC ] C 0 0 0
BUILD: [00:0000000068:PROGC ] Static Libraries 0 0 0
BUILD: [00:0000000069:PROGC ] Exe's 0 0 0
BUILD: [00:0000000070:PROGC ] Dll's 0 0 0
BUILD: [00:0000000071:PROGC ] Preprocess deffile 0 0 0
BUILD: [00:0000000072:PROGC ] Resx 0 0 0
BUILD: [00:0000000073:PROGC ] CSharp Compile 0 0 0
BUILD: [00:0000000074:PROGC ] Other 0 0 2
BUILD: [00:0000000075:PROGC ]
BUILD: [00:0000000076:PROGC ] Total 2 0 2
BUILD: [00:0000000077:PROGC ]
BUILD: [00:0000000078:PROGC ] 0 Warnings, 2 Errors
BUILD: [00:0000000079:PROGC ] GetSystemTimes (seconds): Idle: 5 Kernel: 7 User: 2
BUILD: [00:0000000080:PROGC ] Elapsed time (seconds): 4
BUILD: [00:0000000001:PROGC ] Build started in directory: D:\Radiant\dsplink_35408\dsplink\dsplink_1_65_01_06\dsplink_1_65_01_06\dsplink\etc\host\projects\WinCE\DSPLink
BUILD: [00:0000000006:PROGC ] Scan D:\Radiant\dsplink_35408\dsplink\dsplink_1_65_01_06\dsplink_1_65_01_06\dsplink\etc\host\projects\WinCE\DSPLink\
BUILD: [00:0000000007:PROGC ] Saving D:\Radiant\dsplink_35408\dsplink\dsplink_1_65_01_06\dsplink_1_65_01_06\dsplink\etc\host\projects\WinCE\DSPLink\Build.dat.
BUILD: [00:0000000010:PROGC ] Saving D:\Radiant\dsplink_35408\dsplink\dsplink_1_65_01_06\dsplink_1_65_01_06\dsplink\etc\host\projects\WinCE\DSPLink\Build.dat.
BUILD: [00:0000000012:PROGC ] Done.
BUILD: [00:0000000013:PROGC ] Files Warnings Errors
BUILD: [00:0000000014:PROGC ] Midl 0 0 0
BUILD: [00:0000000015:PROGC ] Message 0 0 0
BUILD: [00:0000000016:PROGC ] Precomp Header 0 0 0
BUILD: [00:0000000017:PROGC ] Resource 0 0 0
BUILD: [00:0000000018:PROGC ] MASM 0 0 0
BUILD: [00:0000000019:PROGC ] SHASM 0 0 0
BUILD: [00:0000000020:PROGC ] ARMASM 0 0 0
BUILD: [00:0000000021:PROGC ] MIPSASM 0 0 0
BUILD: [00:0000000022:PROGC ] C++ 0 0 0
BUILD: [00:0000000023:PROGC ] C 0 0 0
BUILD: [00:0000000024:PROGC ] Static Libraries 0 0 0
BUILD: [00:0000000025:PROGC ] Exe's 0 0 0
BUILD: [00:0000000026:PROGC ] Dll's 0 0 0
BUILD: [00:0000000027:PROGC ] Preprocess deffile 0 0 0
BUILD: [00:0000000028:PROGC ] Resx 0 0 0
BUILD: [00:0000000029:PROGC ] CSharp Compile 0 0 0
BUILD: [00:0000000030:PROGC ] Other 0 0 0
BUILD: [00:0000000031:PROGC ]
BUILD: [00:0000000032:PROGC ] Total 0 0 0
BUILD: [00:0000000033:PROGC ]
BUILD: [00:0000000034:PROGC ] 0 Warnings, 0 Errors
BUILD: [00:0000000035:PROGC ] GetSystemTimes (seconds): Idle: 0 Kernel: 0 User: 0
BUILD: [00:0000000036:PROGC ] Elapsed time (seconds): 0
BLDDEMO: Done Building PostSysgen User Projects
C:\WINCE600\build.err
C:\WINCE600\build.log
C:\WINCE600\build.wrn
已复制 3 个文件。
BUILDREL: Using copylink command
BUILDREL: cleaning up "D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug"
Generating PBWorkspace localization and project files
Done Generating PBWorkspace localization and project files
BUILDREL: Copying SYSGENED binaries from D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\Wince600\OMAPL138_AM18X_ARMV4I\cesysgen\oak
BUILDREL: Copying PROJECT(OMAPL138_AM18X_TI_DEFAULT) binaries from D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\Wince600\OMAPL138_AM18X_ARMV4I\oak
BUILDREL: Copying PROJECT(OMAPL138_AM18X_TI_DEFAULT) files from D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\Wince600\OMAPL138_AM18X_ARMV4I\oak\files
BUILDREL: Copying PLATFORM binaries from C:\WINCE600\platform\OMAPL138_AM18X
BUILDREL: Copying PLATFORM files from C:\WINCE600\platform\OMAPL138_AM18X\files
Can't create hard links between different devices.
Copying files instead of creating hard links.
BUILDREL: Copying PLATFORMCOMMON binaries from C:\WINCE600\platform\common
复制了 1 个文件
BLDDEMO: Calling Makeimg -- Please Wait
makeimg for Windows CE (Release) (Built on Jul 10 2006 16:41:09)
makeimg: Change directory to C:\WINCE600.
makeimg: run command: cmd /C C:\WINCE600\public\common\oak\misc\pbpremakeimg
Generating PBWorkspace Custom makeimg build step batch Files to D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\Wince600\OMAPL138_AM18X_ARMV4I\oak
Done Generating PBWorkspace Custom makeimg build step batch Files
makeimg: Check for D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\PreMakeImg.bat to run.
makeimg: Found localization settings.
makeimg: LOCALE: 0409 LOCALE3: (null) TargetDir: 0409 CodePage=1252 LocaleId: 409 PrimaryLandId: 9 SubLangId: 1
makeimg: Locale is 0409, retrieve files from usasnap directory.
makeimg: Moving files from usasnap to release...
makeimg: Read string substitutions from D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\intltrns\0409\
makeimg: Read string substitutions from D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\intltrns\0409\cebase.str
makeimg: Copy files from D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\intlfile\0409\ to release directory.
makeimg: Creating D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\nlscfg.out because D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\country.cfg doesn't exist or contains a locale different from 0409.
makeimg: run command: fmerge -nls D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\nlscfg.out D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\postproc\nlscfg.inf
fmerge for Windows CE (Release) (Built on Apr 5 2006 11:32:16)
makeimg: run command: fmerge -txt D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\postproc\nlssrc.txt C:\WINCE600\public\common\oak\files\locale.txt D:\BSP_WINCE_ARM9_01.00.00\OSDesigns\OMAPL138_AM18X_TI_DEFAULT\OMAPL138_AM18X_TI_DEFAULT\RelDir\OMAPL138_AM18X_ARMV4I_Debug\nlssrc.txt
makeimg: FATAL ERROR: Command returned non-zero exit code 1 (dec).
BLDDEMO: OMAPL138_AM18X_TI_DEFAULT build complete.
OMAPL138_AM18X_TI_DEFAULT - 6 error(s), 1 warning(s)
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
I wana kow what's wrong with my build,thanks for your reply
