• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » WinCE » WinCE forum » where to change display timing parameters to make a custom 8148 board to with a custom LCD panel in WinCE7
Share
WinCE
  • Forum
Options
  • Subscribe via RSS
This question is not answered
Muthukrishnan Chinnasamy
Posted by Muthukrishnan Chinnasamy
on Aug 09 2012 09:05 AM
Prodigy40 points
We have built our own board using DM8148. It has to connect to an LCD display(640X480 - 33Mhz pix clk with DE only interface
6-bit per pixel). The board also supports HDMI out and we are getting display through that. But even after following TI doc or anything
available on net we are not able to get the display screen up on the LCD panel through Video Out 0/1/2 ports.
Is there a code snippet which we can execute at the end which will do all LCD related programming ?
Please help.
/Muthu
8148
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Brijesh Jadav
    Posted by Brijesh Jadav
    on Aug 11 2012 13:32 PM
    Genius10705 points
    Can you please check you LCD timings in the LCD specifications and configure the same in VOut. Also i think you are using DE + Vsync signals to interface with your LCD.
    Brijesh
    Please mark this post as answered via the Verify Answer button below if you think it answers your question.  Thanks!
    Report Abuse
    • Reply
  • Muthukrishnan Chinnasamy
    on Aug 12 2012 19:30 PM
    Prodigy40 points
    Brijesh,
    Thanks. We had checked/prepared all LCD timings but not able to figure out where is the LCD VOut configuration
    settings file/template/place-holder ? That is our question..
    Wherever we think it should be configured, like by comparing with HDMI_out settings, Linux files for LCD out
    we filled in places but nothing works!! We programmed PLLs, ?*LCD?* related registers etc.. But no signals coming
    out of DM8148. We measured the LCD_out clock, in Linux it comes as 33Mhz(correct for the LCD panel we are using and
    display is up), in WinCE7 no clock is coming or it is coming as 148Mhz which is too high , so LCD display does not show up.
    We want a small code snippet which we want to execute at the end to ensure LCD signals are coming out of DM8148.
    I do not understand why TI cannot give these kind of code snippets so that we customers of TI can use the
    devices readily for every sub-system of the SoCs independent of third party SW stacks and OS'es
    /Muthu
    DM8148 LCD bring up code
    Report Abuse
    • Reply
  • Brijesh Jadav
    on Aug 12 2012 23:35 PM
    Genius10705 points
    Hi Muthu,
    How are you configuring timing for Vout0? Please confiure this in timings syfs attribute under displa0 folder. This will configure the Vout0 as per the timings you require. It is standard format for specifying timings for the display. Once you configure the timing, you enable the display by writing 1 to the enabled sysfs attributes under again display0. This is good enough for programming any display timings..
    Brijesh Jadav
    Report Abuse
    • Reply
    on Aug 13 2012 02:04 AM
    Prodigy40 points
    Hi Brijesh,
       I am (Rajath) working along with Muthu.
    What you suggested is for LINUX, we have seen it working already that is what he has mentioned in his posting.
    Our problem is getting the same display working on WINEC7.Could you send us the same info for WINEC7.
    In WINEC7 HDMI  out is working fine but we have  to get the DVO2 out to the LCD display.
    We have copied the DISPLAY folder under BOOTLOADER and LCDC folder under SP_COMMON for AM387X_BSP(refered from AM33X BSP), but don't know what should be the the AM_DEVICE_LCDC address. Where can we get information on the LCD registers for setting the timings, FB base and ceiling values, panel setting etc.
    All LCD timing parameters we have edited into LCD_panel STRUCT under LCDC.C file.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
