WinCE6 with CETK Test ID 11
When we execute the COM CETK test we found some weird message in the test id 11 result log.
BEGIN GROUP: SERDRVBVT.DLL <TESTCASE ID=11> *** vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv *** TEST STARTING *** *** Test Name: Send bytes at all supported bauds, data-bits, parity and stop-bits *** Test ID: 11 *** Library Path: \serdrvbvt.dll *** Command Line: -p COM1: *** Kernel Mode: No *** Random Seed: 26729 *** Thread Count: 1 *** vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv BEGIN TEST: "Send bytes at all supported bauds, data-bits, parity and stop-bits", Threads=1, Seed=26729 Send bytes at all supported bauds, data-bits, parity and stop-bits on COM1 Calling GetCommProperties() on COM1 COM1 does not support 110 baud Calling GetCommState() on COM1 Calling GetCommTimeouts() on COM1 WARNING in C:\yzqa\private\test\BaseOS\Drivers\Serial\BVT\serdrvbvt\.\testproc.cpp at line 221: GetCommTimeouts() WARNING!! :: WriteTotalTimeoutConstant in serial driver on COM1 == 0.....may create undesired hangs in system Setting WriteTotalTimeoutConstant to 100 so test will not hang Calling SetCommTimeouts() on COM1 Calling SetCommState() on COM1 Sending on COM1 at 300 baud, 5 data-bits, No parity, 1 stop-bits. Failed to send on COM1 at 300 baud, 5 data-bits, No parity, 1 stop-bits. FAIL in C:\yzqa\private\test\BaseOS\Drivers\Serial\BVT\serdrvbvt\.\testproc.cpp at line 286: WriteFile(); error 0
Even we the message show the
Failed to send on COM1 at 300 baud, 5 data-bits, No parity, 2 stop-bits. FAIL in C:\yzqa\private\test\BaseOS\Drivers\Serial\BVT\serdrvbvt\.\testproc.cpp at line 286: WriteFile(); error 0
but the test result is still pass.
Does someone know what's going on about this message.
