• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » WinCE » WinCE forum » Building IMBLIG for WinCE
Share
WinCE
  • Forum
Options
  • Subscribe via RSS
  • David Meixner
    Posted by David Meixner
    on Aug 24 2010 16:19 PM
    Expert3110 points
    I've been working with Linux on OMAP3 for a while, but I'm new to WinCE.  So far, I've been able to build the WinCE DVSDK and run those demos.  Now, I would like to build the IMGLIB demos and run them on WinCE.  Can anyone give me some advice on how to this?  Are there any resources on how to take a Linux project and build it for WinCE?
    David
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Jatin Jain
    Posted by Jatin Jain
    on Aug 25 2010 12:14 PM
    Expert7250 points
    David,
    I'm not very familar with how IMGLIB is called from Linux. Can you clarify whether you are using Codec Engine iUniversal or some other way to access the library on the DSP from the ARM? The DSP part should be pretty much the same between Linux and WinCE. (for e.g, the Codec Server used in OMAP35x Linux DVSDK is same as the one in WinCE DVSDK. Just a recompile to take care of DSPLINK dependency). Details for building codec server is covered in the WinCE DVSDK Getting Started Guide.
    I have not come across any doc that details taking a Linux project and building it for WinCE. But if you look at Codec Engine or DSPLINK builds in WinCE vs the one in Linux it may  give you some idea on how to proceed.
    Jatin
    WINCE OMAP35x IMGLIB
    Report Abuse
    • Reply
  • David Meixner
    on Aug 25 2010 14:23 PM
    Expert3110 points
    Hi Jatin,
    Thank you for your reply.  IMGLIB is a DSP only application, so after building it, you end up with a .out file.  Is there a method for running .out files in WinCE?  Or somehow wrapping this into a .exe?
    The build systems for Codec Engine and DSPLINK are fairly complex, so it's hard to compare them.
    David
    Report Abuse
    • Reply
  • Jatin Jain
    on Aug 25 2010 15:41 PM
    Expert7250 points
    Let me understand what you are trying to do a bit better.
    So you end up with a DSP image (.out or .x64p which i believe is equivalent) and you want to run it from the ARM side? Running .out on WinCE does not make sense (WinCE is only supported on the ARM and .out is for the DSP). So I guess what you really want to do is to download to the DSP from the ARM side and let the DSP run without any further communication with the ARM.  We don't have any other (simpler) standalone WinCE application that will load the DSP. DSPLINK gives that capability but that will need you to write a simple app that talks to DSPLINK to do that (there are some DSPLINK examples especially readwrite test app that show what needs to be done).
    In your current setup with Linux, how do you run the DSP image?
    Report Abuse
    • Reply
  • David Meixner
    on Aug 25 2010 21:59 PM
    Expert3110 points
    Jatin,
    Thanks for putting up with my ramblings.  I think I was trying to run before I could walk.  After looking through the DVSDK a little more, I found the WinCE build instructions for the Codec Engine examples.  I think this is the type of tutorial I was looking for.  Hopefully after running through this, I'll have a better idea of how to leverage the IMGLIB algorithms from a WinCE app.
    Thanks for your help,
    David
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
