• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Consumer & Computing » Consumer & Computing Forum » HDMI or DVI-D (Dual Link) to LVDS Conversion for 10-bit LCD Panels
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 2 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 9 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
Steve Burgess
Posted by Steve Burgess
on Aug 30 2011 22:22 PM
Prodigy80 points
I've just registered and this is my first post - a little about me at the end.
I am hoping to prototype a quite basic picture monitor for high-end applications.  A picture monitor differs from a TV in that it has no provision for audio and does not include a tuner; it differs from a computer monitor in that it is designed to accept a video format rather than a PC format signal.  In CRT technology, picture monitors were designed to add nothing to, or take anything away from, the signals fed to them and used bespoke high resolution CRTs - often with the original delta gun arrangement - and (in Europe) the correct "EBU" phosphors for accurate colorimetry.
My LCD picture monitor would be used with a Lumagen Radiance XE 10-bit video processor which would act as a switcher, take care of deinterlacing of interlaced inputs, upscale standard definition inputs, manage colour and gamma - and always output 1920 x 1080 progressive at 50Hz on HDMI.
I am still to choose my LCD panel - I am looking for: 32 inch : 1920 x 1080 : 50Hz : 10-bit : S-IPS or AS-IPS.  I still have some research to do regarding refresh rate and number of bits.  To preserve picture quality I want to avoid frame-rate conversion and work at 50Hz throughout, but the video processor can convert to 60Hz if I have to work 60Hz.  I'm not sure if true 10-bit (total: 30 bits) panels are available - it seems many 10-bit panels are actually dithered 8-bit (total: 24 bits) panels.  There are two products - a Sony LMD3250MD 32" medical grade monitor and an Ikegami HLM-3250W 32" broadcast grade monitor - which claim to use 10-bit panels which I am investigating.
So, in principle, this is a straightforward task and, once I've chosen my LCD panel, all I need is a means of converting the HDMI signal from the Lumagen Radiance XE video processor to the (multi-port) LVDS signals required by the panel.  I'm not sure yet whether the converter will need a control interface but think this is likely as with ICS's NT15H LCD Controller Board and multi-button NK05A OSD Control Board - see http://www.icsco.kr/what_we_serve/sub_02.asp
So, to summarise I need:
  • HDMI or DVI-D (dual-link) input
  • 1920 x 1080 at 50Hz operation (option: 60Hz)
  • Multi-port LVDS output
Can't be that difficult... can it?
About me: I'm a semi-retired, degree-qualified electronics engineer - I graduated from Imperial College, London in 1979 and then joined BBC TV where I worked as an engineer in their London television studios on the full range of broadcast equipment and have some 30 years' experience designing, building, repairing and modifying professional and consumer electronics.  In 1987 I moved to Channel 4 TV, London where I worked until 2006, at the end as manager of the team of engineers which kept the transmission operations running.
HDMI LVDS DVI-D conversion 50Hz picture monitor
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • RossE
    Posted by RossE
    on Aug 31 2011 18:44 PM
    Expert7555 points
    Hello Steve, thanks for your detailed question.
    I looked up the two monitor models you mentioned, the Sony and Ikegami.  They both appear to have a DVI-D single-link input port.  So if your Lumagen outputs an HDMI signal, that could be directly connected to the DVI ports on those monitors.  As you may be aware, the 3 TMDS data pairs and the 1 clock of HDMI is identical to DVI-D single-link.  So a mechanical adapter can make them connect.
    TI does have a solution for converting HDMI/DVI to LVDS, and even dual-LVDS.  But please let me know if you really need LVDS.
    RE
    Report Abuse
    • Reply
  • Steve Burgess
    on Aug 31 2011 21:33 PM
    Prodigy80 points
    Thanks for your response Ross.
    The monitors I mentioned are seriously over-specified (and over-priced!) for my application.  I mentioned them since they may be using true 10-bit, 32 inch, 1920 x 1080 native resolution panels whereas it would appear that there are no such panels currently used in the consumer domain - they are all 8-bit, or pseudo-10-bit achieved by dithering, I'm told.
    My intention is to purchase an LCD panel - perhaps of the same type as used in one of the aforementioned monitors - and drive it directly from the Lumagen.  If you check the datasheets for these types of panel they require the 24- or 30-bit digital video data describing each pixel to be delivered to the panel's built-in driver board as LVDS - at a refresh rate of 50Hz that's a data throughput of up to 3.1Gb/s.
    The panel data sheets say, for example, "...has been designed to apply the 10-bit 4-port LVDS interface" or "...has been designed  to apply the 8-bit 2-port LVDS interface"
    The Lumagen outputs video of 10-bit word size (or greater) via its HDMI output, so I need a means of converting this to LVDS suitable for my chosen panel.  In concept, an easy job - but maybe more difficult in practice?
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Sep 01 2011 18:37 PM
    Expert7555 points
    Steve,
    I agree that the monitors you mentioned likely support 24-bit pixel inputs, just based on the fact that they use DVI-D inputs.  DVI single-link is inherently 24-bit.
    It sounds like what you need is a TMDS receiver, and a dual-link LVDS transmitter solution.  This is very doable.  If you go the 24-bit color route, the TFP403 is a suitable DVI receiver, and it can output on 48-bits, splitting odd/even pixels.  TI's dual-LVDS solution involves a 1:2 clock fanout buffer and two SN75LVDS83B device.  The primary concern here is skew between the two devices, and it's important for the panel receiver to have skew tolerance.  This has been successfully implemented with an OMAP platform driving a 1920x1200 panel.
    I'm much less familiar with 30-bit color systems.  HDMI receivers that support this are likely available, but I'm not sure about LVDS transmitters, and what standard 30-bit panels use (including the number of LVDS channels and the bit ordering).
    I hope that's helpful!
    RE
    Report Abuse
    • Reply
  • Steve Burgess
    on Sep 14 2011 20:08 PM
    Prodigy80 points
    Thanks for this, Ross.
    I've realised that for 10-bit fidelity I'll need to use HDMI in YCrCb 4:2:2 format as I gather RGB 4:4:4 format is limited to 8-bits for backwards-compatibility with DVI-D.
    I have now obtained the 32" panel I'll be using and have spent some time studying its specifications (all 38 pages!)  The spec was finalised in Feb 2010 - so I guess the panel must be used in some current or recent products.  It's a "10-bit(D)" panel - the "D" may stand for "dithered" but I'm not so sure, now that I have understood how the panel's memory receives digital video data...
    ...which is four pixels at a time, via 4 channels of LVDS, each 5 bits-and-a-clock wide - this reduces the clock from 297MHz to a more manageable 74.25MHz. The clocks drive PLLs producing 7 sampling points per clock cycle coinciding with the 7 data bits sent on each of the 5 lines during each clock cycle - so 35 bits are available to be written to the panel's memory for each pixel - 30 of these are used for 10-bit RGB data.
    I'm not sure whether the above description of the interconnect does or does not exclude the use of dithering.
    The LCD timing controller has pins for JEIDA/VESA select and 8-bit/10-bit(D) select. JEIDA and VESA appear to be data-mapping options for the LVDS interface.
    The panel is specified for 95 to 122Hz refresh rate (not sure what would happen if I try to drive it at 50Hz).
    So, summarising, the job now is to unpack the 10-bit 4:2:2 YCrCb data from the HDMI interface, matrix it to form 10-bit 4:4:4 RGB data, apply some lineartity correction for gamma, double the frame rate to 100Hz (I gather this may mean inserting black frames), and then send the data on 4 channels of LVDS clcoked at 74.25MHz to the panel.
    Piece of cake.
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Sep 15 2011 23:20 PM
    Expert7555 points
    It sounds like you're making progress!
    I suppose you have a 120Hz 1080p panel.  If you tried running at 50Hz (while its spec is 95-122Hz), you'd have a 31MHz clock that's likely too slow for its PLL range.
    RE
    Report Abuse
    • Reply
  • Steve Burgess
    on Sep 18 2011 18:15 PM
    Prodigy80 points
    Thanks Ross.  At 50Hz I make it that the clock would be 37.125MHz but yes, of course you're right, those PLLs (all four of them) would be well out-of-lock.
    I could try and get hold of the 50/60Hz version of the timing controller board and fit this to the panel (100Hz refresh isn't essential - it's just that availability of panels is limited) but the spec for the panel says "The performance of the electro-optical characteristics may be influenced by variance of the vertical refresh rate and the horizontal frequency."  Here's a picture of the 100/120Hz timing controller board the panel came with:
    Report Abuse
    • Reply
  • Mikael M
    Posted by Mikael M
    on Feb 07 2012 11:25 AM
    Prodigy30 points
    (Prio)
    Hi guys,
    I noted you are deeply into the details of an area I'm related to:
    Are you aware of any way of how to make or buy an LCD controller board that produces a double LVDS output, and takes a DVI or Displayport as input?
    The simpler the better. Preferably one that works for different input resolutions.
    Thanks!
    Mikael
    lvds lcd dvi displayport
    Report Abuse
    • Reply
  • Steve Burgess
    on Feb 08 2012 15:15 PM
    Prodigy80 points
    Hi Mikael
    I amassed quite a lot of information during my research into building a full-HD picture monitor based around the 32" LG Display panel I acquired - there's a picture of it under test on my Flickr page:  http://www.flickr.com/photos/38818955@N07/
    I gave up on this project because it would have required far more work than I thought.  There are copyright protection issues associated with decoding an HDMI signal; my panel was a 100Hz panel so I would have had to convert from 50Hz input frame-rate...  I soon realised that the likes of LG basically use a "TV-on-a-chip" solution where all the inputs (HDMI, DVI, analogue) are fed direct to a big chip which does everything, often directly driving the LCD panel without an intermediate T-con board.
    Tell me a bit more about what you're trying to achieve and I might have some leads for you.
    Incidentally, we finally bought an LG TV which uses basically the same panel as the one I bought, so I have a spare.
    Cheers
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Feb 08 2012 17:33 PM
    Expert7555 points
    Mikael, TI has a 2-chip solution to convert HDMI/DVI to LVDS.  It complies with single-link DVI (24bpp) and supports any resolution from 640x480 to 1920x1200:  http://www.ti.com/lit/an/slla325/slla325.pdf
    RE
    Report Abuse
    • Reply
  • Mikael M
    Posted by Mikael M
    on Feb 09 2012 02:16 AM
    Prodigy30 points
    Hi, thank you for your response.
    Is any chip with dual LVDS output about to be released anytime soon (as to support resolutions > 2000px x 1000px)? (as to make a LCD controller with this capability and DVI/Displayport/VGA input)
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Feb 09 2012 11:10 AM
    Expert7555 points
    We have a new device, the SN65DSI85, that bridges dual MIPI DSI to dual LVDS, and supports and output clock of up to 154MHz (2ch), which is higher than VESA's 2560x1600 frequency of 268.5MHz.
    RE
    Report Abuse
    • Reply
  • Mikael M
    Posted by Mikael M
    on Feb 09 2012 12:03 PM
    Prodigy30 points
    Hi Ross - great! Yours is the first mentioning of the SN65DSI85 that I find on the Internet. Where can I read more about it, and where can it be bought or a sample be gotten?
    What would you recommend for turning Displayport or DVI-D into MIPI DSI in the first place?
    Are you aware of any efforts to make anything like a LCD display controller board by any manufacturers of such?
    Report Abuse
    • Reply
  • nisha raman
    Posted by nisha raman
    on Feb 21 2012 00:53 AM
    Prodigy80 points
    hey i am nisha
    i am doing a project where i am trying to interface lcd pannels of differtent resolutions and interfaces using a single board.i am using an omap board but my bord does not have dvi input.its has only lvds interface for lcd so is there any converter which i acan use to convert lvds to dvi so that i can connect dvi supporting monitors.please help
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Feb 21 2012 09:55 AM
    Expert7555 points
    Hello nisha, please clarify: do you need to convert DVI video into LVDS?
    RE
    Report Abuse
    • Reply
  • Mike Wolfe
    Posted by Mike Wolfe
    on Feb 21 2012 17:40 PM
    Intellectual765 points
    Hi all,
    I realize this thread started before the Ti acquisition of NSC was complete, so there weren't many dual LVDS options in the TI portfolio. However, Ti is able to offer a wider selection of LVDS output devices now that the acquisition has closed.
    The DS90C387 is capable of supporting single pixel LVCMOS inputs to single pixel LVDS (SISO), single pixel pixel LVCMOS inputs to dual pixel LVDS (SIDO) and dual pixel LVCMOS inputs to dual pixel LVDS (DIDO).
    The soon to be released DS90C187 is a lower power version of the DS90C387 and operates off of a single 1.8V supply. This device is also capable of supporting SISO, SIDO and DIDO configurations.
    These devices are ideal solutions for dual LVDS output systems because the dual LVDS serialization/conversion can be done in a single device and also without the need for a clock buffer.
    If you have any questions about either device, please let me know.
    Mike Wolfe
    DPS APPS / SVA
    DS90C187 FPD-Link DS90C387
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
