• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Consumer & Computing » Consumer & Computing Forum » SN75LVDS83BDGG Compatibility
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Kent Wise
Posted by Kent Wise
on Sep 16 2011 15:30 PM
Prodigy30 points
Will the SN75LVDS83BDGG LVDS transmitter work with the THine THC63LVDF84B receiver?  One of my customers wants to use a TFT LCD that already has the LVDS receiver built in however it is the THine THC63LVDF84B.  Thanks.
Kent
SN75LVDS83BDGG
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • RossE
    Posted by RossE
    on Sep 16 2011 16:02 PM
    Expert7555 points
    Hi Kent, there isn't enough information in the datasheet I found: http://www.thine.co.jp/products_e/LVDS/pdf/THC63LVDF84B_Rev.3.20_E.pdf
    It needs to comply with the LVDS standard, TIA/EIA-644-A.  And it doesn't state its input common mode voltage range, or input differential voltage range, or whether there's integrated termination.
    Based on its block diagram, there's a good chance it will work with the SN75LVDS83BDGG.  You also want to pay attention to the required serial bit order.  You may be able to find more information by viewing the datasheet of the LCD that has the THine receiver.
    RE
    Report Abuse
    • Reply
  • Kent Wise
    Posted by Kent Wise
    on Sep 16 2011 16:10 PM
    Prodigy30 points
    Thank you for the response.  I have attached the LCD spec sheet link.
    http://www.hedus.com/sales/uploads/TX14D10VM1BAA-2.pdf
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Sep 16 2011 17:24 PM
    Verified Answer
    Verified by ELIAS VILLEGAS
    Expert7555 points
    It looks like it uses the standard LVDS interface, so it'll work with the LVDS83B perfectly.
    RE
    Report Abuse
    • Reply
  • Kent Wise
    Posted by Kent Wise
    on Sep 16 2011 21:56 PM
    Prodigy30 points
    Thank you.  I will let you know how well it interfaces when I receive the LCD.
    Report Abuse
    • Reply
  • openvideo display
    Posted by openvideo display
    on Jun 30 2012 17:16 PM
    Prodigy70 points
    I am using SN75LVDS83, CHMEI LVDS PANEL with CM1718A T-CON
    and found that it looks not working with this LVDS Rx.
    Can you provide any compatible LVDS Rx if you have?
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Jul 01 2012 17:42 PM
    Verified Answer
    Expert7555 points
    openvideo, I haven't seen any LVDS TX and RX devices not be compatible.  Be sure to check your sync timing, and debug connections.
    The complement RX device to the SN75LVDS83 is the SN75LVDS82.
    RE
    Report Abuse
    • Reply
  • openvideo display
    on Jul 16 2012 11:23 AM
    Prodigy70 points
    I am using M185B1-LO2 Panel(Included CH1718A - LVDS Rx)
    and using XGA VESA Standard Timing.
    The Standard timings were probed correctly on Oscilloscope,
    are there any evealution kits for testing of SNLVDS83 Tx or ercommand panels with LVDS Rx?
    When I checked the default Panel Timing after LVDS Rx
    the Horizontal : 37.74khz(STH), vertical : 46.79Hz(STV)
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Jul 16 2012 15:40 PM
    Expert7555 points
    openvideo, what is your LVDS clock frequency?  As for your Vsync frequency, I suggest you try 60Hz since that's much more common, even though the panel datasheet says it supports 40-75Hz.
    To answer your question, we do have EVMs for LVDS transmitters and receivers.  If you used an RX board, it would convert the SN75LVDS83 data into CMOS parallel.  It sounds like you already have this ability, since you measured HSYNC and VSYNC.
    RE
    Report Abuse
    • Reply
  • openvideo display
    on Jul 16 2012 23:57 PM
    Prodigy70 points
    Hi
    the XGA Timing is Pixel Clock - 65Mhz(15.4ns) ,Hysnc - 48.363 Khz(H), Vsync - 60.04 Hz(V).
    I don't have 65Mhz VCO for now, So I am using 66.66Mhz to generate XGA signals, Hsync, DE, Vsync, Color Pattern Pixel Data
    After SN75LVDS83, the Differential Signals looks fine, and the Panel Control Signals on the LVDS Rx(CH1718A, Chimei T-CON IC) looks fine.
    But on the panel side, the STV, STH are coming out, but TP to dump horizontal Pixel, CPV which Horizontal Clock on the Panel is not coming,
    so display is nothing.
    Only different as compared with XGA standard timing is 66.66Mhz instead of 65Mhz(XGA Pixel Clock)
    is it ok for SN75LVDS83 this clock?
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Jul 17 2012 09:59 AM
    Expert7555 points
    Yes, the SN75LVDS83 can be used at 66.66MHz, since it supports 31-68MHz.
    So you are running at:
      PCLK = 66.66MHz
      Vsync = 60Hz
      Hsync = 48.363kHz
    Your panel requires the horizontal time (Th) to be 1446-1936 cycles of Tc.  Tc = 1/66.66MHz = 15ns.  This indicates the required Hsync is 34.4kHz to 46.1kHz.  Try running in this range instead of 48.363kHz.
    RE
    Report Abuse
    • Reply
  • openvideo display
    on Jul 18 2012 02:04 AM
    Prodigy70 points
    The panel is with 1366(Active H) x 768(Active V) , 76Mhz, WVGA Maily
    Th is 768 ~ 888 with 40 ~ 75Hz Frame, Tc is 1446 ~ 1936
    55Mhz ~ 95Mhz, LVDS Clock.
    I have 54Mhz, 66.66Mhz whci can work with SN75LVDS83 and this Panel.
    The panel is only working with DE Mode.
    Do you know the timing specification with 66.66Mhz or 54Mhz for WVGA?
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Jul 18 2012 09:21 AM
    Expert7555 points
    Your resolution is more commonly referred to as WXGA.  The timing spec is entirely defined by your panel datasheet, although VESA publishes their own recommendations.  VESA's DMT doc states 60Hz/47.7kHz/85.5MHz, and a reduced blanking of 60Hz/48kHz/72MHz.  You can also google "VESA CVT" for their Excel calculator.
    RE
    Report Abuse
    • Reply
  • openvideo display
    on Jul 19 2012 11:14 AM
    Prodigy70 points
    I got it.
    I will try to make my onw timings withing the panel specification.
    Thank you so much for your support
    Open
    Report Abuse
    • Reply
  • openvideo display
    on Jul 19 2012 11:33 AM
    Prodigy70 points
    By the way, do you have a EV Kit with LVDS Rx and any size panel for this SN75LVDS83 Testing?
    Report Abuse
    • Reply
  • RossE
    Posted by RossE
    on Jul 19 2012 11:52 AM
    Expert7555 points
    There's an EVM that simply breaks out all the pins.  The CMOS side goes to a header, and the LVDS to SMA  The user needs to control every pin, and figure out how to interface to a panel.  Panels use different connectors.
    RE
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
