• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Consumer & Computing » Consumer & Computing Forum » TUSB3410 Help required
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 2 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 9 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
milap patel
Posted by milap patel
on Mar 25 2009 03:05 AM
Intellectual730 points
have two ICs - TUSB3410 USB IC and 24LC128 Memory IC
Both are fresh and unprogrammed. When I connect my board to PC USB connector, windows can not find the connected device. And in device manger it shows “No device”,” USB device not recognised”.
“First Time Device Should be detect on default VID PID when Blank EEPROM is connected to TUSB3410 ”
My question is how to connect my device to windows So that I can reprogram it to my own VID & PID using EEPROM burner
But for that device should be detect first by windows on default VID & PID stored in TUSB3410
Milap
USB controller
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ismael Duron10236
    Posted by Ismael Duron10236
    on Mar 25 2009 11:32 AM
    Intellectual2170 points
    When you connect a brand new EVM in a PC, that’s the expected behavior (as you said, both EEPROM and TUSB3410 are clean…). There’s a procedure to get the TUSB3410 with default VID/PID recognized by the host PC after the EEPROM burner application (http://www.ti.com/litv/zip/sllc259a) has been installed. Please take a look at “SLLA179A – Using the EEPROM burner”.
    Then you also might take a look to the Header Generator Utility (http://www.ti.com/litv/zip/sllc297). This utility will let you generate a BIN file that can be burned into the EEPROM using the burner app. Follow the “Header Gen User's Guide.txt” included within the utility.
    Thanks and Best Regards,
    Ismael Durón
    Report Abuse
    • Reply
  • milap patel
    on Mar 26 2009 00:12 AM
    Dear sir,
    Yes you are right but for eeprom burner device should be detect first by windows...without that in device seletion menu in eeprom burner application is blank.
    my fresh TUSB3410 is not detect on it's default VID PID. I have thought that TUSB3410 is damaged . But I have changed 3 new TUSB3410 IC. but still windows says device not recognized.
    EEPROM burner is second thing..after detection TUSB3410.
    can u plez Help me out in this problem.
    Milap
    Report Abuse
    • Reply
  • Peter Hull
    Posted by Peter Hull
    on Mar 26 2009 04:26 AM
    Prodigy125 points
    That sounds like the device is functioning but Windows can't find a driver for it. If it isn't working at all you would get a different message (on XP it's a little pop-up bubble down the bottom right of the screen). Try right-clicking in device manager. Check the reported VID and PID. Then maybe try 'Install driver' and point it to the tusb3410.inf file which will be in c:\program files\texas instruments\tusb3410 eeprom installer. However that shouldn't be necessary if the burner installed correctly, certainly I've never had any trouble with it.
    Hope that helps!
    Report Abuse
    • Reply
  • Ismael Duron10236
    on Mar 26 2009 11:07 AM
    Verified Answer
    Verified by DHarmon
    EEPROM-TUSB3410.pdf
    In fact if you’ve successfully installed the EEPROM burner utility, it first installs the EEPROM burner’s driver (that it’s not digitally signed) and then the SW application tool. The burner’s driver needs the TUSB3410 default descriptors, and then it will load a FW that will let the TUSB3410 appear under the USB controllers category at device manager. I've attached to this post a PDF document showing the steps that contains steps for using the Header generator utility, the EEPROM burner app and some other stuff...
    Please let me know if this helps in something.
    Ismael Durón
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
