• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Consumer & Computing » Consumer & Computing Forum » TUSB2036: COM port issues
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    How to determine the power at output of modulator from DAC back-off level
    Posted 21 hours ago
    by Habeeb Ur Rahman Mohammed
    Customers often ask how they can determine the power at the output...
    DAC Essentials: What’s with all this glitch-ing?
    Posted 5 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 7 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
This question is not answered
Sal Garcia
Posted by Sal Garcia
on Mar 21 2012 16:42 PM
Prodigy160 points
I am currently attempting to use a COM port device through this USB hub the TUSB2036. Is there any resources available for making this work. Right now, the device is only being recognized under USB with a USB port and hub number. I tried another commercial USB hub i had and it recognized the device under the COM port section which is what I needed.
-Sal Garcia
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ELIAS VILLEGAS
    Posted by ELIAS VILLEGAS
    on Mar 22 2012 17:40 PM
    Mastermind23840 points
    Hello Sal,
    I am not sure I understand, are you saying that you want to interface a USB port with a COM port (UART) ?
    If so, there is a dedicated device for this, the TUSB3410
    Regards.
    Report Abuse
    • Reply
  • Sal Garcia
    on Mar 26 2012 17:59 PM
    Prodigy160 points
    ELIAS VILLEGAS
    Hello Sal,
    Regards.
    It is a device that connects via a UCB cable but it shows up on a windows computer as a COM port in Device manager. We were looking for a software solution because the TUSB2036 has to be used for this design since the PCB were already printed and everything was designed around it.
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Mar 27 2012 15:48 PM
    Hello Sal,
    What is your COM device? OS ?
    Regards.
    Report Abuse
    • Reply
  • Sal Garcia
    on Mar 27 2012 18:37 PM
    Prodigy160 points
    It's called the HI-pro USB hearing aid programmer.
    http://www.otometrics.com/fittingsystems/Fitting/Hi-Pro_USB.aspx
    This is the USB version, whereas the previous version just used a RS232C port. It may even have a RS232 to USB adapter inside so that it could work on a USB port but still pops up as a COM port.
    Report Abuse
    • Reply
  • Sal Garcia
    on Apr 15 2012 00:32 AM
    Prodigy160 points
    Any updates?
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Apr 16 2012 13:27 PM
    Hello Sal,
    I don't think some modifications to the hub will make a change, with the TI's USB-to-Serial converter (TUSB3410) we've seen this behavior with some drivers.
    Have you asked to the RS-232 device's manufacturer? The TUSB2036 is not High-speed capable, does the device's driver works with only Full-speed?
    Regards.
    Report Abuse
    • Reply
  • Sal Garcia
    on Apr 18 2012 14:01 PM
    Prodigy160 points
    The device is the Hi-pro hearing aid programmer. From their site:
    Built-in USB 2.0 connection (USB 1.1 compatible)
    So i dont believe it is an issue with USB Full speed or high speed compatibility. Please let me know
    -Sal
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Apr 19 2012 17:31 PM
    Hello Sal,
    Are you able to get a USB bus trace captures?
    Can you send your schematics?
    Regards.
    Report Abuse
    • Reply
  • Sal Garcia
    on May 14 2012 20:12 PM
    Prodigy160 points
    I can't get a bus trace right now but here are the schematics. I am connecting the downstream device to JP2.
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on May 15 2012 11:21 AM
    Hello Sal,
    Connect a pull-up to 3.3V on each /OC input.
    Your downstream device should have an integrated pull-up on D+ or D-, you don't need the R8U.
    Is JP2 a USB type A connector?
    Regards.
    Report Abuse
    • Reply
  • Sal Garcia
    on May 15 2012 11:48 AM
    Prodigy160 points
    I actually already added those pull ups on the OC inputs but this schematic does not show that.
    The JP2 is just a jumper connector from my PCB to the device's D+, D-, Vbus, and GND inputs directly.
    The device did have a USB A connector previously but I desoldered it and hardwired it for a more permanently attached device.
    -Sal
    Report Abuse
    • Reply
  • Sal Garcia
    on May 21 2012 12:32 PM
    Prodigy160 points
    Any thoughts?
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on May 21 2012 13:26 PM
    Hello Sal,
    Could you send us your system fro debug?
    You can send me an email to elias.villegas@ti.com to get the contact information.
    Regards.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
