• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Consumer & Computing » Consumer & Computing Forum » TUSB9261 - bios boot troubles when firmware loaded - firmware options
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 17 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
This question is not answered
pierre-louis royer
Posted by pierre-louis royer
on Apr 13 2012 03:01 AM
Prodigy70 points
I have implemented the TUSB9261 on my board and have some troubles with the firmware when loaded:
The issue:
When the flash is burned with the TUSB926x_FW097.bin firmware, the boot process on my board is blocked in usbHID process.It is working well with the demo board.
The test I have made:
  • I have duplicated the SPI flash from the demo board and solder the new one directly on my board without using the flash burner.
    In this case, it does not stop the boot process but it does not work because of the inverted polarity in differential pair.
    I understood that we cannot read back the descriptors and firmware binary from the SPI flash with the flashburner software. I also have understood that the flash burner always modify the firmware binary file by including the descriptors choosen in the software.
  • I have burned the SPI flash with the TUSB926x_FW097.bin firmware and try different options: UAS/HID/HIDinterrupt/HIDcontrol validated or not. I did not try all solutions because it is time consuming. I did not found the right option to not block the boot process.
Is it possible to have some explanation and there consequences concerning the different options? Is it also possible to know what are the options used by the demo board?
Thank you in advance for your answer,
PLR
TUSB9261 TUSB926x TUSB9260
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ELIAS VILLEGAS
    Posted by ELIAS VILLEGAS
    on Apr 13 2012 11:44 AM
    Mastermind23085 points
    Could you clarify your following statement: "I have duplicated the SPI flash from the demo board and solder the new one directly on my board without using the flash burner.
    Also, can you try with the Firmware version available at http://www.ti.com/product/TUSB9261#technicaldocuments.
    Regards.
    Report Abuse
    • Reply
  • pierre-louis royer
    on Apr 16 2012 03:08 AM
    Prodigy70 points
    Hello Elias,
    I mean I have made a binary image from the demo board SPI flash and burn a new one with a flash programmer. In this case it works fine (except that I should invert polarity on one of the differential pair as the demo board).
    I have tried with the firmware available at http://www.ti.com/product/TUSB9261#technicaldocuments, but I think I do not use the right parameters.
    PLR
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Apr 16 2012 15:48 PM
    Hello Pierre-Louis,
    The flash burner will add some information to the binary code, so if you make an image of an already programmed memory and you use that binary code as the firmware to be burned on another memory then after the flash burner you will have a memory with duplicated descriptors information (see Figure 3-1 of the TUSB9260 Flash Burner - User Guide)
    The HID and UAS command support is describe on the TUSB9260 Flash Burner - User Guide at the below link.
    Regards.
    http://www.ti.com/lit/ug/sllu125b/sllu125b.pdf
    Report Abuse
    • Reply
    on Apr 18 2012 07:15 AM
    Prodigy70 points
    Hello Elias,
    Is it possible to know what the parameters are for the demo board?
    Thank you,
    Pierre-Louis
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Apr 19 2012 12:13 PM
    The default settings are HID Enabled, UAS Enabled and Self-powered Device.
    You should also upgrade to the latest firmware (rev 98) available at http://www.ti.com/product/tusb9261#technicaldocuments
    Regards.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
