• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Consumer & Computing » Consumer & Computing Forum » USB 3 Repeater cable (SN65LVPE502 redriver)
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 23 hours ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 7 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
Simon Kaempflein
Posted by Simon Kaempflein
on May 25 2012 07:43 AM
Prodigy50 points
We have  an application where we need more than 3m cable between our USB-3 device (Cypress FX3) and the host. So our idea was to use a USB-3.0 repeater cable (also called "active cable") for this scenario. The cables we had here for testing are build with a SN65LVPE502 Chip.
It works if both sides support USB-3 or both sides only support USB-2.
But if the host side only supports USB-2 and the device supports USB-3, no connection is established (no device shown in Windows/device manager). We found out that in this case the SN65LVPE502 does not hold the input terminations at HiZ, causing the peripheral device only to try to connect in USB-3 mode. If we force the SN65LVPE502 in sleep mode (connect EN_RXD to ground), it works (but of course the configuration USB-3 device <-> USB-3 host not).
Configuration:
USB-2 Host-Controller <-> SN65LVPE502 <-> USB-3 Device
Questions:
a) Is the SN65LVPE502 designed/applicable for repeater/active cables, espescialy with USB-2 Host and USB-3 device?
b) Does this scenario work with the new SN65LVPE502A Version?
Simon
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ELIAS VILLEGAS
    Posted by ELIAS VILLEGAS
    on May 25 2012 10:32 AM
    Mastermind22725 points
    Hello Simon,
    A USB 3.0 host or device has actually two different physical connections: one for USB3.0 and one for USB 2.0
    If you have a USB 2.0 Host and you connect a USB 3.0 device, the connection will be made always over the USB 2.0 physical wires and the USB 3.0 signal wires will be unused.
    The SN65LVPE502 only re-drives the USB 3.0 differential signal pairs, it behaves like a pass-through for the USB 2.0 signals.
    Go to the below link for more information.
    Regards.
    http://e2e.ti.com/support/interface/digital_interface/f/130/t/163721.aspx
    Report Abuse
    • Reply
  • Simon Kaempflein
    on May 29 2012 02:49 AM
    Prodigy50 points
    Hello Elias,
    thanks for your reply!
    If the USB-3 physical wires are not connected (e.g. USB-2 host <-> USB-3 device, without redriver), it work's without problems.  The connection is established through UBS-2 physical wires like you described.
    But when we use the "active cable" with the redriver, the fall back to USB-2 does not work. The problem seems to be the "far end receiver termination detection" (USB-3 spec Fig. 9-1), that the USB-3 device uses to detect if there is a receiver at the USB-3 physical wires. The redriver does not set the input termination to HiZ in this configuration and the device thinks there is a USB-3 receiver and does not fall back to USB-2.
    Configuration not working:
    USB-2 Host <----------------------USB-2 physical wires ---> USB-3 Device
                                          redriver <--USB-3 phy. wires------>
    Simon
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on May 29 2012 15:56 PM
    Simon,
    The LVPE502 is actually detecting the USB 3.0 device because you do have a USB 3.0 device attached, that is why it is not setting its RX TX lines to Hi-Z.
    Anyway, your host is USB 2.0, so your host is not connected to the LVPE502 at all, I don't understand why your host would "look" for the Hi-Z of the LVPE502.
    Can you elaborate more on your application, do you have the cable's schematic, diagrams, etc? What is your USB 3.0 device?
    Regards.
    Report Abuse
    • Reply
  • Simon Kaempflein
    on May 30 2012 02:00 AM
    Prodigy50 points
    Thanks Elias,
    ELIAS VILLEGAS
    No, it seems that the device "looks" for the Hi-Z of the LVPE502 and does not fall back to USB-2. And because the host does not support USB-3, no connection is established.
    ELIAS VILLEGAS
    Our idea is to ship the "active cable" with the LVPE502 with our device (Cypress FX3) because we need more than 3m cable length (in our device there is already about 1.5m cable). But we also need to be compatible with USB-2.0 hosts.
    Simon
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on May 30 2012 16:22 PM
    Simon,
    Do you have the schematic of the active cable?
    The LVPE502 should set its RX and TX to Hi-z when any of its two sides is not connected, probably your cable is terminating the RX terminals of the LVPE502.
    Also, what is the part number of the device?
    Regards.
    Report Abuse
    • Reply
  • Simon Kaempflein
    on May 31 2012 03:28 AM
    Prodigy50 points
    Elias,
    I sent you the schematic by email. The device is a Cypress FX3 (http://www.cypress.com/?id=3526) and we also tested with an USB-3.0 harddrive from Western Digital (WDBACY5000ASL).
    Simon
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on May 31 2012 15:39 PM
    Hello Simon,
    I've just double-checked and the LVPE502 enters to RX.Detect when there is no device detected on any of its channels.
    Check that the USB 3.0 type-A connector does not have any termination on the SS lines, also, your USB 3.0 device should fall back to USB 2.0 when there is no far-end  receiver termination or when the link training was unsuccessful, so even if the LVPE502's receiver is not in Hi-Z the devices should connect over USB 2.0, can you check this with your device.
    Regards.
    Report Abuse
    • Reply
  • Simon Kaempflein
    on Jun 01 2012 03:11 AM
    Prodigy50 points
    Hi Elias,
    thank you for your commitment. I made some further tests:
    1) To make sure that the type-A connector does not have any termination on the SS lines, I cut the SS lines at the redriver PCB (RX and TX, host direction). But the problem is still there (LVPE502 receiver not Hi-Z!). I also measured the type-A connector and found no termination on the SS lines.
    2) I forced the LVPE502 to sleep mode (Pin RX_EN -> GND), now the device is detected (-> LVPE502 receiver Hi-Z, device falls back to USB-2).
    3) I cut only the TX lines in device direction (LVPE502 -> device), now the device is also detected (-> LVPE502 receiver Hi-Z!).
    It seems that the LVPE502 does not set it's receivers to Hi-Z when just one receiver (USB-3.0 device in this case) is connected.
    I also don't understand why the devices do not fall back to USB-2.0 even if the LVPE502 receiver is not in Hi-Z mode. I tested another USB-3.0 device (USB stick) and the behaviour is the same. We will have a closer look at the device behaviour of the Cypress FX3 next week, but I have not much hope that the problem lies there because other devices also do not work.
    Simon
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Jun 14 2012 12:05 PM
    Hello Simon,
    Do you have the "CP" version of the LVPE502?
    Because I think you are seeing a known problem described on the errata, this problem is fixed on the "A" version.
    You can see the errata at http://www.ti.com/lit/er/sllz070/sllz070.pdf
    Regards.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
