• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » Consumer & Computing » Consumer & Computing Forum » Connection sequence of the TUSB2046
Share
  • Forum
  • Files
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 2 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 9 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
GABRIEL FIGUEROA
Posted by GABRIEL FIGUEROA
on Jul 11 2012 00:28 AM
Prodigy150 points
TUSB2046 for TI.pdf
Please tell me as...? I have connected in a TUSB2046 entries in DM1, DM2, DM3 and DM4, four circuits with PCM2900C respectively PCM2900 (1), PCM2900 (2)... etc.
When connecting the circuit to the PC, you should install in the first instance DM1, DM2 and then sequentially so... this is correct...?
Thanks for your time.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ELIAS VILLEGAS
    Posted by ELIAS VILLEGAS
    on Jul 11 2012 15:20 PM
    Mastermind22725 points
    Hello Gabriel,
    The USB Host will start configuring the downstream ports form D1 to D4, however it will not stay fixed on one port until it is fully configured and then go for the next, I mean for example the host will send to the hub the configuration command SET_PORT_POWER to port 1 then to port 2 and so on, after that, the host will send a configuration command like PORT_RESET to port 1 then to port 2 and so on.
    So technically if all the downstream devices are powered and ready the host will end the configuration of the device on port 1 then port 2 and so on.
    Regards.
    Report Abuse
    • Reply
  • GABRIEL FIGUEROA
    on Jul 30 2012 15:08 PM
    Prodigy150 points
    It happens that I have connected 4 codec PCM2900C on the same circuit TUB2046 in Windows appear as:
    USB AUDIO CODEC
    USB AUDIO CODEC (2)
    USB AUDIO CODEC (3)
    USB AUDIO CODEC (4)
    Where it is assumed that USB AUDIO CODEC should be the one connected to D1, USB AUDIO CODEC (2) should be the one connected to D2 and so on, but unfortunately as the computer that connects to this correlativity does not happen often, income audio inputs connected PCM2900c Ocurri D4 and can see it reflected in USB aUDIO CODEC (3) for example.
    I could do to make sure the correlativity of this ..?
    Thank you very much.
    Report Abuse
    • Reply
  • ELIAS VILLEGAS
    on Jul 31 2012 10:48 AM
    Hello Gabriel,
    Unfortunately this is out of the scope of the hub, the driver will be the one who assigns the identifiers according which device reported first.
    Regards.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
