Hi All,
Our customer consider to use both USB 3.0 SuperSpeed and USB 2.0 High-speed, but use Hub for only USB 2.0 as below. Do you have any concern for such configuration? Your comments will be appreciated.
Sonoki / Japan Disty
Hi All,
The TUSB9261 requires to be connected to one single upstream port, it can't be connected to two different USB ports.
In your block diagram, assuming on of the Host's ports is disabled then it could work but that is a non-standard application and I don't think you could ever pass compliance testing.
Regards.
