Dear TI,
I am using TUSB7320 (EVAL board) with dart MX6 freescale based chip from variscite and these are the errors I am getting (See below).
It works with renesas chipset usb 3.0 hub but not with TI TUSB7320 chip, Could it be a driver issue? is there a specific driver that works with these chip or should it work just with the default installed driver? (TUSB7320/TUSB7340)
Please Help,
usb-storage 3-2:1.0: USB Mass Storage device detected
scsi3 : usb-storage 3-2:1.0
scsi 3:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI: 6
sd 3:0:0:0: [sdb] 60751872 512-byte logical blocks: (31.1 GB/28.9 GiB)
sd 3:0:0:0: [sdb] Write Protect is off
sd 3:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sdb: sdb1
sd 3:0:0:0: [sdb] Attached SCSI removable disk
usb 3-2: reset SuperSpeed USB device number 10 using xhci_hcd
usb 3-2: Parent hub missing LPM exit latency info. Power management will be impacted.
xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep a8a0a800
xhci_hcd 0000:01:00.0: xHCI xhci_drop_endpoint called with disabled ep a8a0a82c
sd 3:0:0:0: [sdb] Unhandled error code
sd 3:0:0:0: [sdb]
Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
sd 3:0:0:0: [sdb] CDB:
Read(10): 28 00 00 00 00 80 00 00 f0 00
end_request: I/O error, dev sdb, sector 128
Buffer I/O error on device sdb, logical block 16
Buffer I/O error on device sdb, logical block 17
Buffer I/O error on device sdb, logical block 18
Buffer I/O error on device sdb, logical block 19
Buffer I/O error on device sdb, logical block 20
Buffer I/O error on device sdb, logical block 21
Buffer I/O error on device sdb, logical block 22
Buffer I/O error on device sdb, logical block 23
Buffer I/O error on device sdb, logical block 24
Buffer I/O error on device sdb, logical block 25
