Is there a way to detect connected devices (enumerated) on TUSB4041I ?
In the datasheet a read that the cpdEN bit of Device Configuration Register 2 can anable or desable Device attach detec in auto mode.
many thanks
many thanks
If you are using power switches to control VBUS to the downstream ports you can use that signal to know when a USB device is attached, the TUSB4041I will assert the PWRON# signals to turn on the VBUS, this is kind of indirect solution and if there is an over-current condition you will loose that flag.
