Team,
The SN75DP139 datasheet lists a minimum data rate of 0.25 Gbps. What is the reason for this limitation? Are lower data rates possible?
Phil
Hi Clemens,
The lowest resolution 640x480p uses a clock rate of 25.175MHz, this would be 0.25175Gbps per lane.
So, DP139 supports all the resolutions without problem.
