Referring to the XIO2001 datasheet (revision January 2016) section 6.12.1, it's stating that the GRST and PERST to the device must be asserted and then the supplies applied. Should the GRST and PERST be asserted low with a logic driver or is it sufficient to use a pull-down resistor? Is one method safer than the other?
