Other Parts Discussed in Thread: HD3SS213,
Hi Sirs,
Sorry to bother you.
As title, does HD3SS213 can support eDP1.4 signal?
Thanks for your reply.
Hi Shu-Cheng,
eDP1.4 is based on DP1.2a which uses HBR2(5.4Gbps), in this case, HD3SS213 would be enough.
If you have DP1.3/1.4 these versions use HBR3(8.1Gbps), in this case, you need HD3SS214.
Since HD3SS214 supports 8.1Gbps. it will work for eDP1.4 too.
