Hai,
Can any one suggest IC compatible with audio mixing and having above 60db gain and also with low noise.
Thanks & Regards,
Prasad.
Hai,
Thanks & Regards,
Prasad.
Hai Ivan,
1. I need 6 channel mixer. First three channels used for dynamic mic and condenser mic ,remaining three channels used for line input's. Output channels required is two.
2. I need gain of about 60db for each channel.
3. Input signal nature is analog.
4.Low noise.
Thanks & Regards,
Prasad.
Hai Ivan,
Thank you for your reply. Can i know the best suitable op-amp for my application,as i mentioned in previous post. Which is having high gain of about 60db and low noise.
Thanks & Regards,
Prasad.
