Hello there, I have a system that uses the DPHY440SS to buffer a long MIPI CSI2 bus. However I cannot get the 440 to switch into HS mode: It seems to be stuck in LP or ULPS state. All the signals on the inputs look OK, and I can see the correct LP11 -> LP01 -> LP00 sequence on the data inputs. But there is no clock or HS data on the outputs (the LP signalling is present on the outputs).
Can you send me the list of extended registers for this part (as mentioned in the related E2E posts)?
Many thanks
