Other Parts Discussed in Thread: TDP142
Hi
Customer is using SN75DP130DSRGZT to build a redriver card, a daughter board.
They found there is no charging when select different voltage swing and pre-emphasis. The output waveform is same.
But without the redriver card, the output waveform is changing as setting.
Could you help with it ?
