can you please confirm if the TPS65982 can also work with the Spansion S25FL116K Flash device?
What would be the parameters to specifically check with Spansion to ensure that these work together?
Thank you and best regards,
Dirk
Dirk
Hi Jacob,
thank you. Sorry to insist, but can TI give a statement if the TPS65982 works with the Spansion S25FL116K Flash device - I guess that we could judge if there is any issue due to the slower clock rate of the Spansion? Otherwise, could we recommend any other Q100-qualified Flash device for the TPS65982?
Dirk
