Am looking at the TS5A3159A to act as a switch for the precision clock signal from a TCXO to a GPS receiver. The TCXO frequency would be in the 16~26MHz range.
It appears the TS5A3159A, which may be targeted at audio, may have the bandwidth to perform well, but I’m not sure about distortion. Can you comment about this use case?
Dan
The frequency is no problem and it has 1 ohm on resistance so the distortion should be low..
