• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » Signal Switches Forum » Analog Switch or Multiplexer
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 15 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the right input and output characteristics, but a signal chain approach...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical cable equalization , on the High Speed E2E forum (more than 3,700...
This question is not answered
dison wang
Posted by dison wang
on Mar 09 2012 17:39 PM
Intellectual570 points
  I need select some switch for I/O signals go to diffence way. the signal will come from RM48 MCU to FPGA and connecter. Could you give me a answer about  that questiones list below.
  1. Can I use a  Analog Switch or Multiplexer for that. like ts5a3359? Is  the TS5A3359 twoway  path,I can use any I/O as a input ?
  2. If I use a Analog Switch or Multiplexer for a digital path, what parameters will be important?
DW
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Eric Nachtigal
    Posted by Eric Nachtigal
    on Mar 12 2012 14:52 PM
    Prodigy450 points
    Hi Dison,
    I'll be happy to help. For many applications analog switchs can be used for digital signals. It however depends on your specific situation. If you could give me some more information about the signals you will be passing, and the project in general I can help point you to some of our products that will be the best fit for your needs. The most important factors will be:
    -Frequency of the signal
    -Amplitude of the signal
    -What if any communications standard you are useing (I2C, SPI, CAN, etc.)
    -# of Channels
    With these parameters I can help narrow down TI's catalog for you. Hope your day is going well and I hope I can be of some assistance to you.
    -Eric
    Report Abuse
    • Reply
  • dison wang
    on Mar 12 2012 18:37 PM
    Hi Eric,
    Thanks for your reply.
    I am designing a test project with indeterminate I/O and communication  by RM48. So I have to leave every speaical interface and I/O for future as RM KID BOARD. For the reason, I will need a USB host, A USB device ,SPI4, LINE,I2C Ethernet and may change them to GIO.
    I chose TS5A3159 for 1 SPDT, TS5A23159 for DPDT, SN74CBTLV3257 for 4PDT, TS5A3159 for 1 SP3T. I just consided the Vin=3.3v, BW > 100MHz, Continuous current through>100mA,Capacitance of the path (choice of the smaller ones AFAP ) and ON-state resistance<10 ohm. Please help  me make sure that the choice of parameters is  applicable or not.
    I still need DP3T ,8P2T and 8P3T. I can not found them in TI's products. Could you give me some advice?
    Others , Could you tell me what difference among the TS5Axxxxx , SN74CBTxxxx, SN74LVC1Gxxxxxx.
    Best Regars,
    Dison
    Report Abuse
    • Reply
  • Eric Nachtigal
    on Mar 15 2012 13:59 PM
    Prodigy450 points
    Dison,
    For the 8PDT and 8P3T switches you are looking for it would most likely be best to run 2 and 3 8:1 bidirectional muxes in parrallel respectivly. For the DP3T it depends. I would say your best bet is to use 3 DPST switches in parrallel to avoid timing issues.
    From what I am seeing the RM48 has a large number of high speed differental logic communications standards supported and these would best be handled with more specilized digital communications interface devices. http://www.ti.com/lsds/ti/analog/interface.page?DCMP=TIHomeTracking&HQS=Other+OT+home_p_interface will link you to a catalog with most of our digital communication switches/muxes. I personaly specilize in analog applications and have familiarity with our passive USB 2.0 switches so I'm afraid I may not be of much help if you are looking to transmit a wide array of high speed digital communication signals. I'll find the right person to help you with your project.
    Eric
    Report Abuse
    • Reply
  • dison wang
    on Mar 26 2012 18:40 PM
    Hi Eric,
    Thank you for help!
    Dison
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
