• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » Signal Switches Forum » TS5A26542 Application Question
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 1 day ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the right input and output characteristics, but a signal chain approach...
    Cable equalization 101 – Automating your design
    Posted 4 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical cable equalization , on the High Speed E2E forum (more than 3,700...
This question is not answered
David Escandon
Posted by David Escandon
on Apr 05 2012 17:42 PM
Expert2155 points
TI Team,
I would like to get some clarification about the TS5A26542 SPDT analog multiplexer. The datasheet is not clear about the conditions under which a switch pin is left unconnected. Here are my queestions:
Questions:
  • According to the datasheet, the VIO logic supply operation rate is from 1.65v-1.95v but its absolute maximum rating is 6.5v. I was wondering what would be the disadvantages of connecting the VIO to 2.2V supply? would it affect device reliability or performance? Our V+ max supply is 5.5V. The datasheet says you can connect this pin to a higher voltage as long as you don't exceed the input-clamp current. How do you calculate the threshold?
  • Based on design I need to use only one of the NC or NO pins for each switch, is it okay to leave either not connected or should I tied it back to output. It's usually customary to pullup or pulldown unconnected pins. What is your opinion for this switch line?
  • 3. What is the maximum leakage through the switch and would it be different on NO, NC and COM pins? (assuming NC floating(not connected), and logic low for NO connection (but having high voltage on NO pin)). Although the datasheet specifies a maximum current of 100nA, will this apply if either the NC or NO is left floating. Again, this comes back to my first question.
-David
Unconnected Pins TS5A26542 CMOS Multiplexers
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Eric Nachtigal
    Posted by Eric Nachtigal
    on May 03 2012 11:46 AM
    Prodigy450 points
    David,
    1.) I spoke with one of our designers, he took a look at the device and sent this in reply: "I don't see any major concerns with Vio=2.2V.  ... The only current consumption increase would be if the customer did not drive the input to the 2.2V rail, but to a lower “high” voltage."
    As per the datasheet the triggering voltages will be:
    • .65 x Vio for Logic High min threshold
    • .35 x Vio for Logic Low max threshold
    We can not 100% guarantee long term stability of the device under these conditions. However talking with the design engineers, it seems that there should only be a minimal extra current draw and no long term damage from regularly operating this device at Vio=2.2V. Hope this helps!
    2.) Any unused NO, NC or COM pins on this switch should be pulled down to ground with a 1k-10k resistor.
    3.)Could you please clarify your question. As it stands all of the NO,NC,COM leakage currents are currently listed in the datasheet on page 4 for 5.5V V+
    Eric Nachtigal
    Report Abuse
    • Reply
  • David Escandon
    on May 03 2012 18:57 PM
    Expert2155 points
    Eric,
    Thanks for responding to my post.
    In regards to question 3, I want to know if the leakage current number will (100nA) change if either the NC or NO is left floating.
    -David
    Report Abuse
    • Reply
  • Eric Nachtigal
    on May 10 2012 19:10 PM
    Prodigy450 points
    David,
    We recommend using a 10k resistor to ground on all unused NC or NO pins. Leaving the pin floating should have no affect on the leakage current and in some cases can cause instability or even damage in the device.
    Eric
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
