the TS3USB30E documentation states "The device multiplexes differential outputs from a USB host device to one of two corresponding outputs".
In my application I have a USB flash drive which I need to switch between two USB hosts - would the TS3USB30E be suitable?
Hi Brian,
Sorry for the delay, I hope you found the answer you needed! For others who may have similar questions, TS3USB30E is a bidirectional switch. You are able to use it for 2:1 multiplexing.
Ryan
