• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » ESD/EMI Forum » TPD2E009DRT Versus TPD2EUSB30DRT
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    DAC Essentials: What’s with all this glitch-ing?
    Posted 4 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you expect the output to move from one value to the next monotonically...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 6 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making a composite amplifier , but we had yet to replace the ideal...
This question is answered
Daniel Jackson
Posted by Daniel Jackson
on Jan 06 2012 14:29 PM
Prodigy100 points
In a current USB3 Superspeed design the TPD2EUSB30ADRT was designed in, but appears to be completely unavailable currently.
As a possible temporary work-around alternative (although somewhat less desirable for USB3 Superspeed applications), the TPD2EUSB30DRT has been considered, but is also unavailable, at least in the 300-quantity range needed for the current initial build about to happen shortly.
A yet further alternative which actually is available is the TPD2E009DRT, which appears to have electrical characteristics similar to those of the TPD2EUSB30DRT.
Per the website information posted however (under Interface; ESD/EMI Protection; browsing for parts in the 3SOT package), while the TPD2EUSB30DRT (and TPD2EUSB30ADRT) appear to be recommended for use in a number of highspeed serial applications including HDMI, PCIE, SATA/eSATA, and full, high and superspeed USB, the TPD2E009DRT is shown as recommended only for SATA/eSATA.
What is the reasoning for such a disparate set of recommended applications for what appears to be two virtually-dentical parts?
Is there any obvious (or nonobvious) reason why the TPD2E009DRT could or should not be used in place of the TPD2EUSB30DRT?
TPD2E009 TPD2EUSB30
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Sagir Hasnain
    Posted by Sagir Hasnain
    on Jan 06 2012 15:30 PM
    Verified Answer
    Verified by Daniel Jackson
    Prodigy300 points
    TPD2EUSB30DRTR & TPD2E009DRTR are identical parts. Same silicon, same package. We created different marketing part# to address USB3.0 interface. this is why you see different application info at different data sheets.
    TPD2EUSB30ADRTR is a lower VBR version of the TPD2EUSB30DRTR. Everything else is identical. We had one particular customer wanted lower VBR to pass a surge test.
    TPD2EUSB30ADRTR 7V (min) VBR
    TPD2EUSB30ADRTR 4.5V (min) VBR
    Report Abuse
    • Reply
  • Daniel Jackson
    on Jan 06 2012 16:00 PM
    Prodigy100 points
    Sagir,
    Thank you for your prompt and clear explanation.
    If you don't mind the suggestion, why not indicate, either on the TI website, or on the products' datasheets, or both, that the two parts are in fact interchangeable, i.e. identical?  Doing such would have saved me at least some time and effort, and no doubt others as well.
    Do there happen to be any other parts available, identical (or almost so) to the TPD2EUSB30ADRT?
    TPD2E009 TPD2EUSB30
    Report Abuse
    • Reply
  • Sagir Hasnain
    on Jan 06 2012 18:14 PM
    Prodigy300 points
    Daniel, We have TPD2E009DRTR units available right now. This can be a choice if customer don't mind the VBR change. If this is an option, please send an email to Janna Harris (and copy me) if you like to have some units.
    I will look into the suggestion and see how we can implement. There are some marketing consederation against doing that.
    Sagir
    Report Abuse
    • Reply
  • Daniel Jackson
    on Jan 07 2012 01:07 AM
    Prodigy100 points
    Sagir,
    Thanks for the offer for providing units, but an order has already been placed with Digikey for a quantity of the parts.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
