• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » I2C Forum » Possible PCA9555 power-on-reset problem, will TCA9555 help?
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 2 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical cable equalization , on the High Speed E2E forum (more than 3,700...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 6 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most versatile communication standards when it comes to industrial...
This question is not answered
Stan70812
Posted by Stan70812
on Apr 08 2011 11:05 AM
Prodigy30 points
We occasionally see incorrect values in PCA9555 registers 4 and 5 (the Polarity Inversion registers). Our software never intentionally writes to these registers and we rely on the power-on-reset circuit to properly initialize them.I had thought that we must have a software bug causing this, but then I read that the TCA9555 addresses a problem with power-on-reset with the PCA9555, so I am now pursuing that.
We power the PCA9555 off of a 3.3V supply and the supply ramps up linearly over 3mS. Shutdown is less well controlled, especially when the supply gets below 1V and takes around 5mS. We see this register corruption on about 3% of our products.
Does this seem like the type of problem that would be addressed by the TCA9555?
I2C PCA9555 IO expander 3.3V
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Mark Welty
    Posted by Mark Welty
    on Apr 08 2011 16:46 PM
    Prodigy210 points
    Stan,
    To provide a good reset signal, the power-on-reset (POR) circuit of the PCA9555 requires a supply ramp time from 0V to VCC that is less than about 10ms.   Also, to achieve a good reset, the POR circuit requires a powered-off (VCC<0.2V) duration of greater than ~700mS.   You appear to meet the first condition, but I can't tell from your post whether you meet the second condition.
    The TCA9555 addresses both of the above restrictions and should properly reset over a much wider set of conditions.   The applications section of the TCA9555 datasheet provides information on the TCA9555 POR characteristics.
    -Mark
    Report Abuse
    • Reply
  • Phil54870
    Posted by Phil54870
    on May 19 2011 10:40 AM
    Prodigy105 points
     we are experiencing similar problems with PCA9555. The ramp is almost linearly rising from 0 to 3.3V in 4ms. At first startup, the PCA9555 doesn't work at all or only the lower 8 bit port is working (we have connected LEDs at both ports).This is weird enough: it seems, as if I2C is working, but the upper port is not...
    Interestingly, all 4 I/O-expanders on the PCB show the same behaviour in parallel. If power is disconnected and reconnected within a few seconds, they get a propper power-on-reset and are then all working fine. A delay (PCB powered off) of more than 10 seconds gets the problem back again.
    I have been finding an improvement in slowing down the rise-time of the supply voltage >> 500ms. However this doesn't guarantee reliable behaviour.
    I also have been observing, that the PCA9555 seems to get a supply without its VCC connected (possibly through the clamping diodes, adress pins of I2C or I/O pins?). This also seems to corrupt the filtering on the dedicated VCC pin (1 Ohm resistor, decoupling capacitors). The PCA9555 gets its power just anywhere power is present: How can I really tell, what the power on reset detector is getting his ramp from?
    I haven't been measuring any glitches, voltage is well filtered and monotonically rising.
    The datasheet indicates a "no load condition" for the power on reset -voltage. How serious is that condition to be met? (If I have LEDs connected at the outputs, it's hard to guarantee a no load condition during power up).
    Is there any know issue about the PCA9555? Is there any workaround to get them working somehow or forcing them to reset (without touching VCC)?
    In what way do the PCA9555 from TI and NXP differ? Are they based on the very same die? Is there any hope to get a better result with TCA9555 like Stan proposed?
    Thanks for your help,
    Phil
    Report Abuse
    • Reply
  • Phil54870
    Posted by Phil54870
    on May 30 2011 07:21 AM
    Prodigy105 points
    Any chance for an answer...?
    Phil
    Report Abuse
    • Reply
  • Stan70812
    Posted by Stan70812
    on May 31 2011 09:30 AM
    Prodigy30 points
    Hi Phil,
    I never saw the lockup problem you describe where the upper port doesn't work at all.
    I also verified that my power supplies meet the ramp up requirements, but I have no way to guarantee that the supply voltage drops below 0.2V between power cycles. Once my supply gets below 0.7V, there isn't much draw and it can take several seconds for it to leak down to below 0.2V.
    I also have some I/O pins on the part which are hooked to other supplies, so there may be a parasitic power path that we are triggering.The Absolute Maximum Ratings on this part says -0.5 to 6V. I usually interpret that to mean I can raise the voltage on an I/O before applying power to the part without a latch-up issue, but that might not be the case on this part since there is a 100K resistor between each I/O and the power pin.
    I rewrote my firmware to not rely on the POR working properly and then designed out this part.
    Stan
    Report Abuse
    • Reply
  • Akhil Nair
    Posted by Akhil Nair
    on Jun 01 2011 17:40 PM
    Intellectual1635 points
    Phil,
    It is hard to say what exactly the reason might be for what you are seeing, without looking at your entire application setup. The easiest thing to do would be to replace the PCA9555 with a TCA9555 and see if your problem goes away. If it doesn't then we can look at other options. I'm sorry I don't have a more concrete answer at this time.
    Report Abuse
    • Reply
  • owais ahmad
    Posted by owais ahmad
    on Feb 27 2012 18:54 PM
    Prodigy50 points
    Stan,
    We are having similar issues.  Could you please share how you rewrote your firmware not to rely on the POR?
    Thanks!
    Report Abuse
    • Reply
  • Stan70812
    Posted by Stan70812
    on Feb 28 2012 09:18 AM
    Prodigy30 points
    Hi Owais,
    Our firmware now immediately writes the default values to all of the registers in this part, rather than relying on the POR within the PCA9555.
    I also removed TI from the AVL for this part. There are other vendors with a compatible part that have a less fussy POR.
    Stan
    Report Abuse
    • Reply
  • owais ahmad
    on Feb 28 2012 09:25 AM
    Prodigy50 points
    Thanks Stan.
    We will try this approach.
    Would you mind sending me the part# of the part that you are now using and are having success with.  Fortunately we are at the time in the project that we can make this change before production begins.  You can PM me to oahmad@atitest.com.
    Thanks Again!
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
