• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » I2C Forum » TCA8418 - Device Address Configuration
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 1 day ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the right input and output characteristics, but a signal chain approach...
    Cable equalization 101 – Automating your design
    Posted 4 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical cable equalization , on the High Speed E2E forum (more than 3,700...
This question is not answered
Scott Kerstein
Posted by Scott Kerstein
on Nov 29 2011 09:41 AM
Expert1215 points
If one wanted to use multiple TCA8418 within a system, the device address must be unique.  I see in the spec that there is a register which allows one to write to it and change the I2C slave address.  If I'm interpreting the datasheet correct, it looks like the default is 0x69 during a read operation, but that doesn't make sense because there isn't a defined register.
I'm assuming you can reconfigure it since there isn't a fixed I2C address called out in the spec.
Thanks, in advance.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Akhil Nair
    Posted by Akhil Nair
    on Dec 01 2011 13:43 PM
    Intellectual1635 points
    Scott,
    I'm not sure whihc register you are referring to when you say that a register can be used to configure the address. THe TCA8418 has a fixed I2C address as shown in Table 4 of pg 13 of DS. This is 0x69 as you have noted in you message and it cannot be changed.
    Akhil.
    Report Abuse
    • Reply
  • Scott Kerstein
    on Dec 02 2011 14:29 PM
    Expert1215 points
    Thanks.  What's the purpose of the bit 0, if you can't write to it?
    Report Abuse
    • Reply
  • Aditya Kumar
    Posted by Aditya Kumar
    on Mar 20 2012 03:53 AM
    Prodigy200 points
    Hi..
    I am trying to develop driver to access the keypad present on my Am1808 based evm. The keypad controller according to the schematic is
    TCA8418.After going through the data sheet for tca8418 , i found that the I2C Slave address is 0110100x. The last bit of the slave address
    determines the operation(read/write)to be performed.
    Please tell me which hex i2c slave address should I mention in my header file i.e
          #define TCA8418_I2C_ADDR     __?__
    0110100=0x34
    01101000=0x68  (Read-1)
    01101001=0x69 (write-0)
    Thanks.
    Report Abuse
    • Reply
  • Aditya Kumar
    on Apr 02 2012 08:41 AM
    Prodigy200 points
    Friends,
    The I2C slave address for TCA8418 is 0x34 . I am able to access  the registers of tca8418 using this address. !
    Report Abuse
    • Reply
  • Akhil Nair
    on Apr 02 2012 14:38 PM
    Please make sure your I2C address you are sending matches the Bit pattern shown on pg 13 of DS. Depending on conventions used, the addres might be considered either 0x34 or 0x68.
    Report Abuse
    • Reply
  • Aditya Kumar
    on Apr 02 2012 22:59 PM
    Prodigy200 points
    Hi Akhil,
    I have tried with all the 3 possible address combinations ( among them 0x34 is working fine). But  registers like INT_STAT(0x02), KEY_EVENT_(A-G),KEY_LCK_EC are still
    not accessible . I am using i2c_smbus_read_byte_data ,i2c_smbus_write_byte_data function to read and write to these registers.
    Can you please guide, what can be done ?
    Aditya
    Report Abuse
    • Reply
  • Akhil Nair
    on Apr 03 2012 10:59 AM
    Aditya,
    Unfortunately I'm not familiar with the SW functions that you mentions. If you can send me scope shots of the I2C lines when these commands are transmitted I might be able to tell you what the problem is.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
