• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » I2C Forum » TCA4311A Startup problem
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most versatile communication standards when it comes to industrial...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters before the birth of software? They were able to do it using nomographs...
This question is answered
Ankit Kumar
Posted by Ankit Kumar
on Apr 17 2012 04:59 AM
Prodigy160 points
I am using TCA4311A I2C bus Buffer and i am facing problem in power on startup of this device i.e. the buffer_ready output does not go high.
I have checked the voltages on all pins and the following is observed:
VCC = 3.3V
SDAOUT = 3.3V
SCLOUT = 3.3V
EN = 3.3V
But BUFF_REady output is still 0V... :) and it should have gone high i.e. 3.3V.
Also i observed voltages on
SDAIN= 1.1V
SCLIN= 1.1V
As the buffer does not let the incoming I2C lines to be connected to outgoing I2C lines untill buffer_ready is high, i am not able to connect the master to slave at all.
Please suggest me a solution.
Thanks ,
Ankit Kumar
I2C buffer Logic
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Jim Le
    Posted by Jim Le
    on Apr 17 2012 13:23 PM
    Prodigy620 points
    Hi Ankit,
    The 1.1V you're seeing on the input side is from the TCA4311A precharging the input bus through a very weak pull-up.  This indicates that there is a problem w/ the SDAIN/SCLIN side external pull-ups.  Please confirm that the external pull-ups are populated and that  the external pull-up supply has been enabled.
    Jim
    Report Abuse
    • Reply
  • Ankit Kumar
    on Apr 18 2012 01:21 AM
    Prodigy160 points
    Thanks a lot sir..The pull up resistors for SDAIN and SCLIN  are at backplane and i had not inserted the card in backplane while measuring the voltages.
    Now it is confirmed that the buffer is working absolutely fine; also input and output lines are connected.
     Now  the acknowledge comes from TPS2459 but i am not able to write to the register of TPS2459....
    Problem Descritption:
    I have one master card with Stellaris LM3S2965 as I2C master and it is connected to TPS2459 power supply hot hot swap controller ( slave) on I2C Bus  in backplane
    I am trying to write to the register of TPS2459 but the data is not getting written....although i am able to receive the acknowledgement of the address...
     I doubt the following:
    TPS2459 datasheet suggests 2.2K pull up on SDA line only (not on SCL line).
    But i have used TCA4311A buffer between controller and the TPS2459.
    And therefore i have used 10K pull ups on both side of TCA4311A
    [not 2.2K pull up on SDA line only..instead 10K on both SDA and SCL (as suggested in datasheet of TCA4311A ) of TPS2459]
    Whether this is the reason for unsuccessful data send/register updating
    The following is the status of registers related to I2C of LM3s2965 in debugger:
    MCR = 0X0010
    MSA = 0X0018
    MCS = 0X0020
    DATACK, ADRACK, BUSBSY, ERROR , BSY .........ALL THESE BITS ARE RESET
    BUT MDR= 0X0000....I DONT KNOW WHY?
    Please help.
    Report Abuse
    • Reply
  • Jim Le
    Posted by Jim Le
    on Apr 18 2012 10:16 AM
    Verified Answer
    Verified by Ankit Kumar
    Prodigy620 points
    Hi Ankit,
    Just as a sanity check, please confirm that the slave address matches that of the TPS2459.  According to your MSA register, the slave address being written to is "0001100"  (after removing the r/w bit).  This would correspond to A2=L, A1=NC, and A0=NC for the TPS2459.
    If the address is definitely correct and you're not reading back the correct data that you programmed in, then the next step is to confirm that the data on the bus matches the expected data using a scope on both SDA and SCL.  With a repeater on the line, you'll need to look at the waveforms on both sides (i.e. what the master puts on the bus and what the slave actually sees).  One possibility, especially if you're using the max I2C clock frequency, is that the time of flight through the repeater might affect the setup/hold times seen by the master/slave.
    Hope this helps.
    Jim
    Report Abuse
    • Reply
  • Ankit Kumar
    on Apr 19 2012 07:38 AM
    Prodigy160 points
    Thanks alot...
    I was sending data in single send mode and that is why TPS2459 was not getting written...
    But when i sent in Burst Mode .....it got written...
    Thanks again...
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
