TCA9546APWR Testing with Total Phase Aardvark
Other Parts Discussed in Thread: TCA9546A
I am trying to test TCA9546 functionality on my board using total phase aardvark. I2C is from a processor which is multiplexed by TCA9546A . I am unable to test or change register settings with using Aardvark. what would be the procedure? Please help.
  • Hi, Could you please post reset signal waveform?Thanks
  • Does the Aardvark have internal pull-up resistors on SDA and SCL?
    If so, what is their value?
    If not, then that is your problem, because I do not see any pull-up resistors on SDA/SCL in your schematic.
    Please provide us the data log from the Aardvark if you have checked the pull-up resistors and verified the values.
    Make sure the slave address is shown somewhere.
    Also, please provide scope shots clearly displaying SDA and SCL for a full Read or Write command (9 bits for the Slave Address and ACK, and 9 bits for the data and ACK).
