Do you recommend that the A-side pins must be connected to the master device if the power supply for VCCA and VCCB is 5.0V ?
Could you please give us your advice about it ?
Kato
Kato
Kato-san,
Is there a plan to use multiple TCA9517 devices, or only 1 on this bus line?
It does not matter which side is connected to the master. Please note that B-sides of the device cannot be connected to the same node if you need signal to propagate through them both.
Hi Jonathan-san,
Thank you for your quick response.
Our customer is considering to use one TCA9517.
I understood.
Kato
