[ TCA9517 ] Requirements for Level Translating Application
My customer has been working on the project for few years which uses multiple TCA9517s for their I2C level translation block. According to latest datasheet, new ”Design Requirements” added, and it must be met “Vcca < Vccb”.
Q1: Can you elaborate why this requirements added from latest datasheet?
Since previous datasheet does not have this kind of requirements, so their design already has some blocks that do not meet with “Vcca < Vccb” requirement, they have to modify their schematics.
Q2: According to customer experience, it can be seen that the level translating function with Vcca > Vccb (not meet with requirement) is more sensitive to noise from adjacent function block. (the block with Vcca < Vccb is less sensitive.)
Does this make sense? Can you explain how this difference on noise performance caused?
Q3: The changes only on datasheet, TI has NOT changed anything of TCA9517 itself. Correct?
(We, disti in Japan, have received PCN which is related to adding fab and wire material changes)
Thank you for your support on this matter in advance.
Ken
