• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » Voltage Level Translation Forum » issue voltage with TXB0108PWR
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    Cable equalization 101 – Automating your design
    Posted 1 day ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical cable equalization , on the High Speed E2E forum (more than 3,700...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 5 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most versatile communication standards when it comes to industrial...
This question is answered
Olivier BERTRAND
Posted by Olivier BERTRAND
on Aug 01 2012 04:33 AM
I try to use the TXB0108PWR by putting 3,3V (with a wire) on the A pins and obtain 5V on the B.
But with these schematics I'm using (see attached files) I don't obtain exactly 5V : sometimes the B pins are around 2,4V and sometimes it's 5V.
The values are stable but they can change between 2 mesures.
However I used the same schematic as in the datasheet, OE is linked to VccA... I don't understand.
Help me please.
Thank you.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Junjie Mai
    Posted by Junjie Mai
    on Aug 01 2012 04:57 AM
    Intellectual2990 points
    Could you please let me know which pin on which part did you measured?
    Actually, in your design, for U1, you have the I2C signal and also the B side SCL and SDA have the 4.7Kohms pull up resistor,  this design is not correct.
    The TXB0108 can not be used to transfer the I2C signal(open drain) , also for any pins, if you want to add the pull up resistor, the resistor should be larger or equal to 50Kohms.  you can see the detail in the datasheet.
    So you can replace U1 with TXS0108, I think you can find the Pin-Pin compatible part, this TXS part can be used for both Open drain and push pull signal translation. the key concern is about the input frequency, the TXS0108 can handle 60Mbps at 3.3V to 5V translation while the TXB0108 can handle 100Mbps.
    If you still have issue, please let me know.
    BR
    Junjie
    Report Abuse
    • Reply
  • Olivier BERTRAND
    on Aug 01 2012 06:45 AM
    Verified Answer
    Verified by Junjie Mai
    Intellectual0 points
    OK concerning the  I2C, I didn't check it yet ...
    And for the pins, I checked everyones (from A1 to A8 for U1 and U2). That's my main issue...
    Maybe I shouldn't use a wire to verify a pin by linking the Inputs with the 3,3V from the card (that's how I simulate a high level transition) ?
    Is the TXS0108 have more stability?
    thank you.
    Report Abuse
    • Reply
  • Junjie Mai
    on Aug 01 2012 23:14 PM
    For either TXB and TXS part, please use the switch signal to check these parts. that will be better.  Because the transfer direction and transfer trigger is caused by the signal rising or falling at the input pins.  actually if you connect the input to the 3.3V directly, the output side should be work an have high output. if you still have the issue, please make sure you have the stable connection for the input and also easure the waveform of input and output to see whether any findings.
    BR
    Junjie
    Report Abuse
    • Reply
  • Olivier BERTRAND
    on Aug 08 2012 03:48 AM
    Hello Junjie,
    I checked the waveform signals with an oscilloscope, it's OK...
    I tried to put a serial RS232 protocol (9600bps) side 3,3V but it doesn't work, is it too quick ?
    I read in the datasheet tha it is recommanded to put all the i/o unused at the GND, and on my schematics as you can see it's not done...
    So, do you think it doesn't work because of this ?...
    cordially.
    AM3517
    Report Abuse
    • Reply
  • Olivier BERTRAND
    on Aug 08 2012 04:44 AM
    sorry the exact designation is UART, not RS232.
    Report Abuse
    • Reply
  • Junjie Mai
    on Aug 13 2012 22:29 PM
    Hi, Olivier,
    Could you please let me know which part and which pins did you measured? and what your input and output waveform looks like?
    For TXB0108, it is OK to transfer the signal with 9.6MPBS from 3.3V to 5V translation, it should be no issue. so please let me know the details.
    BR
    Junjie
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
