We have an excess current problem affecting a large percentage of our products. The SN74AVC32T245 we use to translate between the 1V8 bus of our DSP chip and the 3V3 bus of an SD host controller chip appears to be drawing an amount of current up to 50mA.
The current varies from unit to unit but each unit is stable at a particular current draw. This additional current draw is remarkably stable across active and hibernate modes of the unit . If the 32T245 is removed the current drops by at least 2/3 and if a new device is fitted the current draw will also generally drop.
Is it possible the device could have been damaged, e.g. by latch-up, during the power on sequence of the device? Unfortunately our circuit does not contain the nOE pull-ups recommended in the data sheet.
Pete.
