Hi
Is this device 74GTL2003 capable of auto-direction, the datasheet does not seem to indicate it capable of that. It requires pull to specify direction, correct?
This is first time I come across this device for application 3V3 to 5V0 with bidirectional pin connection. The GPIO signal on 5V0 side could be open drain or push-pull type.
I should use TXB0108E or TXS0108E for this purpose, it has auto direction without dependency of pull resistor, correct?
