I am looking for hot insertion –bus switch similar to sn74cb3t3125, input signals will be 800MHz. Do we have such a device?
Robin,
I filtered the switch and muxes parametric tables on TI.com for device with bandwidths greater than 800MHz and SPST 1:1 configuration. The results are here or pictured below.
I will move this thread to the level shifters forum since this device has level shifting capability as well as bus isolation switch. I don't know if you customer wants the level shifting or just the 800MHz signal bus isolation.
Thank you,
Adam
