• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » RS-232 Forum » MAX3232 Problem
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    DAC Essentials: What’s with all this glitch-ing?
    Posted 4 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you expect the output to move from one value to the next monotonically...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 6 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making a composite amplifier , but we had yet to replace the ideal...
MAX3232 Problem
MAX3232 Problem
This question is not answered
Andrew Messier
Posted by Andrew Messier
on Jun 10 2011 14:31 PM
Prodigy10 points
I'm having a heck of a time getting the MAX3232 on my board to operate correctly. I've attached a snippet of my schematic and screen shots of all the relevant pins. I'm not sure what the C+/- pins are supposed to look like, but I can certainly see a lot of ripple on the V+ and  especially V-. The RS232 output has the data I expect basically modulated with this ripple. My terminal will display the correct character about 80% of the time but the other 20% is garbage.
I've checked and replaced the 0.1UF capacitors
I've checked the ground connection to the PC
I've checked that VCC looks pretty clean
I've| checked my schematic and layout symbol for errors.
 I've checked multiple boards (I doubt the part is bad)
The one thing that I did see was that in my layout the V+ and V- caps are connected through fairly small vias which may be causing series inductance. However I was able to solder on caps to the pins on the chip to bypass these inductors and the same problem occurred.
Note that the images I'm supplying are with the serial connection connected. If I open it up I still see the ripple, but it's a lower frequency (maybe a clue)
I've used these types of chips plenty of times before without any problem, I'm pretty stumped here.
Oops, when I originally posted I though I could update files. I'll just describe what I'm seeing: On my V- line a see -6 volts with about 2 volts of saw-tooth on top of it. I also see this saw-tooth on my data.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Robert Regojo
    Posted by Robert Regojo
    on Jun 13 2011 12:20 PM
    Intellectual1000 points
    I would verify your capacitor values, they depend on the level of your Vcc. On page 7 of the data sheet it specifies the different capacitor values you should use.
    Robert Regojo.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
