• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » RS-232 Forum » SN75155 RS-232 Driver Issue
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 1 day ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the right input and output characteristics, but a signal chain approach...
    Cable equalization 101 – Automating your design
    Posted 4 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical cable equalization , on the High Speed E2E forum (more than 3,700...
This question is not answered
John Nobile
Posted by John Nobile
on Jul 22 2011 10:22 AM
Prodigy40 points
I am trying to use this as just a driver, but I cant see anything on my hyper terminal. The chip works fine as a receiver, since I can send text from my hyper terminal to the chip and see the output on an LCD screen. I have the chip running at 5VDC. Is there anything else I need to add to the circuit to get the chip to work as a driver?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ron Michallick
    Posted by Ron Michallick
    on Jul 22 2011 15:04 PM
    Mastermind30490 points
    Hello John,
    The SN75155 requires dual supplies; the range is +/-4.5V to +/-15V.  Do you have a -5V on pin 1 (VCC-)?
    If you only have a +5V supply, I suggest a single supply devices , like the TRSF3221E .
    Ron Michallick
    Ronald Michallick
    Linear Applications
    TI assumes no liability for applications assistance or customer product design. Customer is fully responsible for all design decisions and engineering with regard to its products, including decisions relating to application of TI products. By providing technical information, TI does not intend to offer or provide engineering services or advice concerning Customer's design. If Customer desires engineering services, the Customer should rely on its retained employees and consultants and/or procure engineering services from a licensed professional engineer (LPE).
    Report Abuse
    • Reply
  • John Nobile
    on Jul 25 2011 07:35 AM
    Prodigy40 points
    Right now, I had it running at 5VDC on pin 1. Would I need to have a 15VDC powersupply hooked up to pin 1 in order for this thing to operate properly?
    Report Abuse
    • Reply
  • Ron Michallick
    on Jul 25 2011 10:56 AM
    John,
    There should be a negative supply on PIN1 (VCC-) and a postive supply on pin 8 (VCC+).
    Pin 1 = -5V and Pin 8= +5V is good.
    Pin 1 = -12V and Pin 8= +12V is better
    Pin 1 = +5V and Pin 8= +5V is not good.
    Ron Michallick
    Ronald Michallick
    Linear Applications
    Report Abuse
    • Reply
  • John Nobile
    on Jul 25 2011 11:45 AM
    Prodigy40 points
    Sorry, yes that is how its set up, -5 on pin 1, +5 on pin8.I have the signal from my microprocessor going to pin 2, and pin 7 going to the RS232 connection on my PC.No other parts hooked up to the circuit. Still doesnt seem to work, even at the 12VDC =/
    Report Abuse
    • Reply
  • Ron Michallick
    on Jul 25 2011 14:27 PM
    John,
    Now that the supply voltage have been verified, it is time to measure the voltages on the 'DA" and 'DY' pins.
    Measure the 'DA" input voltages. Verify the VIH is at least 2V and VIL is less than 0.8V.
    If the 'DY' voltages meet the VOH and VOL values on page 4 of the data sheet, check the RS232 wiring to the PC.
    If the voltages are bad, try unplugging the RS232 cable and measure again.
    If still bad, try changing the SN75155.
    Ron
    Ronald Michallick
    Linear Applications
    Report Abuse
    • Reply
  • John Nobile
    on Jul 26 2011 10:23 AM
    Prodigy40 points
    I hooked up a scope to the DA and DY pins to make sure the voltages were correct. DA was between 0-5VDC. DY was a little high with the rs232 connected to it, but removed, it was within the acceptable range. I still see nothing on my hyper terminal. When I checked the DY signal, it looks like it is stuck high, at around 5VDC. The DA signal is sending the message, so the levels go between 0-5VDC. I went through 10 of the chips that I had, to make sure that the one wasnt bad, but they all showed the same values. My circuit configuration is: -5VDC to pin 1, +5VDC to pin 8, Serial in from Microprocessor to pin 2, serial out to pin 7, GND of the serial connected to pin 4.  Should I have the GND pin also put to -5VDC?
    Report Abuse
    • Reply
  • Ron Michallick
    on Jul 26 2011 14:45 PM
    John,
    When using the +/-5V supply, the DA signal should be less than +4.3V.
    If it is stuck at 5V, check for a board short between pins 7 & 8. (DA and VCC+)
    The device schematic shows a base emitter (diode) drop then 360 ohms (60 + 300) when driving high. So DY(high)=VCC+ - 0.7V - Iout*360 ohms.
    Ron
    Ronald Michallick
    Linear Applications
    Report Abuse
    • Reply
  • B. Sims
    Posted by B. Sims
    on Dec 18 2011 12:08 PM
    Prodigy10 points
    I see that this is old and may have been worked out but my 2 cents? I think all you need to do is turn on the local echo in Hyperterminal. In Hyper Terminal go to File - Properties. In Properties choose the Settings Tab and then the  ASCII Setup button. In ASCII Setup check the box  "echo typed character locally".
    RS232
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
