• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Interface » /etc... Interface » RS-232 Forum » Multiple MAX3221 Use Scenario
Share
/etc... Interface
  • Forums
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 7 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the right input and output characteristics, but a signal chain approach...
    Cable equalization 101 – Automating your design
    Posted 2 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical cable equalization , on the High Speed E2E forum (more than 3,700...
This question is answered
Sridhar Jonnalagadda
Posted by Sridhar Jonnalagadda
on Jan 25 2012 00:26 AM
Prodigy140 points
Dear TI Team,
We are using 2 - MAX3221 (Rev M) devices in our application that requires communication with an embedded module (RS-232 port) and also a PC (RS232). The baud rate is 115.2kbps. The system is powered with a 3.3V supply.
In our application, we use a microcontroller with a single H/W UART module to drive both these MAX3221 devices. In order to facilitate this, we intend to use the following configuration.
- Tie the FORCEON pin of both the MAX3221 devices to 3.3V
- We toggle the !EN and !FORCEOFF pins to be able to receive/transmit from PC or other embedded module. We have the following commonly used scenarios,
Case (A) - Receive from Embedded Module and Transmit to PC
Embedded Module side - MAX3221 configuration
- FORCEON = High
- !EN = Low
- !FORCEOFF = Low
PC side - MAX3221 configuration
- FORCEON = High
- !EN = High
- !FORCEOFF = High
Case (B) - Receive from PC and Transmit to Embedded Module
- FORCEON = High
- !EN = High
- !FORCEOFF = High
- FORCEON = High
- !EN = Low
- !FORCEOFF = Low
We will be switching b/w the configurations depending on when we receive the interrupt from either the embedded module or PC.
In context of the above, i had the following queries
1) The datasheet specification is 100us for driver enable to valid data at the output and 200ns for receiver enable to valid output. Assuming we follow these specifications, do you see any other limitations with our proposed use scenario?
2) The datasheet specs the typical values, is there data on the max value? We intend to assess the max value and design the system accordingly.
3) On a separate note, do you see any limitation in using MAX3221 to drive about 20ft of cable @ 115.2kbps (this is the max distance b/w the embedded system and our controller)
Sridhar
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ron Michallick
    Posted by Ron Michallick
    on Jan 25 2012 11:33 AM
    Mastermind30480 points
    Because there is no maximum value, I suggest a conservative 400uS to allow the charge pump to turn on and stabilize.
    For the receiver the same guard band can be used which is 800nS.
    Provided that the cable capacitince is less than 1000pF, the signal will be good.
    Ron Michallick
    Ronald Michallick
    Linear Applications
    TI assumes no liability for applications assistance or customer product design. Customer is fully responsible for all design decisions and engineering with regard to its products, including decisions relating to application of TI products. By providing technical information, TI does not intend to offer or provide engineering services or advice concerning Customer's design. If Customer desires engineering services, the Customer should rely on its retained employees and consultants and/or procure engineering services from a licensed professional engineer (LPE).
    Report Abuse
    • Reply
  • Ron Michallick
    on Jan 25 2012 11:38 AM
    Sridhar,
    For question #1.
    The multiplexing scheme will work well provided that the remote RS232 ports do not transmit while your application is looking at the other RS232 port.
    Ron
    Ronald Michallick
    Linear Applications
    Report Abuse
    • Reply
  • Sridhar Jonnalagadda
    on Jan 27 2012 06:28 AM
    Prodigy140 points
    Ron,
    Thank you, appreciate your prompt support. These numbers are ~4x higher (400us for TX drivers and 800ns for RX) and are probably NOT characterized. Please advice. Our budget looks a little tight if we were to use these numbers and hence wondering if some sort of Silicon/Characterization data is available for the same?
    Unfortunately after ordering MAX3221 parts, we saw the following on the TI website " TI recommends the MAX3221E in new designs. The MAX3221E is an improved direct drop-in replacement for the MAX3221".  Do you see any serious limitations in pursuing with MAX3221? What are the enhancements in MAX3221E (as against MAX3221) vis-a-vis the application use scenario that i had described earlier?
    With Best Regards,
    Sridhar
    Report Abuse
    • Reply
  • Ron Michallick
    on Jan 27 2012 12:35 PM
    Sridhar,
    The test program does not check power up time so I can't use data logs to get a timing distribution.
    Because I had no data available, I gave very conservative guidance.
     The start up time is likely faster when VCC is 5V.
    What is your VCC and what are your timing requirements? I may be able to lab test some samples.
    The "E" suffix gives improved ESD and EOS protection on the RS232 port pins.
    Ron Michallick
    Ronald Michallick
    Linear Applications
    Report Abuse
    • Reply
    on Jan 29 2012 23:27 PM
    Prodigy140 points
    Ron,
    Thank you!
    The system VCC is 3.3V (Typical).  For the transmit side, we should be fine with 200us budget. Appreciate if you could help check the same in the lab and let us know.
    Sridhar
    Report Abuse
    • Reply
  • Ron Michallick
    on Jan 30 2012 12:41 PM
    Verified Answer
    Verified by Sridhar Jonnalagadda
    MAX3221 ForceOFF Release Timing.zip
    Sridhar,
    I checked several samples of MAX331 devices.
    The force off release to DOUT active time delay of the samples (14 units) varied from 69uA to 72uS (VCC=3.3V).
    I attached waveform from one unit for DOUT, V+ and V-.
    The output load does not change the time. However, variance in values for charge pumps capacitors can affect delay.
    Lowering VCC to 3.0V increase delay by 16uS; Increasing VCC to 3.6V lowered delay by 13uS. So VCC is a factor.
    I expect 200uS to be sufficient delay, but my small sample does not conclusively prove this will be the case.
    If there are concerns about the delay, then a multiplexer chip , 'OR gate' equivalent, or analog switch could be inserted in to the UART to dual MAX3221 path.
    This way the drivers do not have to be turned off.
    Ron Michallick
    Ronald Michallick
    Linear Applications
    Report Abuse
    • Reply
    on Jan 30 2012 22:13 PM
    Prodigy140 points
    Hi Ron,
    Thank you. This answers my query and i would like to appreciate the prompt response and excellent technical support.
    With Best Regards,
    Sridhar
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
