need to make RS232 with two option:
- Voltage level +/-5v (Standard )
- Voltage level 0-5 (TTL )
I would like to control the mode by Software
Do you have any solution/ application?
Eli,
A RS232 receiver will accept both voltage levels, but the load is 5k to ground.
For the RS232 transmitter, I suggest a relay to switch between the RS232 output and a TTL bus driver output.
