Hi all
The external capacitors C1,C2,C3,C4 are recommended to be 0.1uF by datasheet.
Is there any problem if I use 1uF capacitors ?
thanks and best regards.
Charlie
Hi all
Charlie
Charlie,
It will be fine provided that VCC = 3.3V.
Hi Ronald Michallick
Thanks very much for your rapid reply.
When Vcc=3.3V , which is better? 0.1uF or 1uF ?
thanks .
BR
Charlie
Charlie,
0.1uF is how the device is normally used and VCC noise is less. 1uF allows for capacitance reduction with temperature and voltage modulation (capacitor properties).
