Hi all,
Would you mind if we ask DP83848I?
First of all, please refer to the attachment file.
4341.20140927_Attachmentfile1.pdf
We have some questions as Q1~Q3, so could you tell us some advice?
We need your help.
Kind regards,
Hirotaka Matsumoto
Hi all,
We need your help.
Kind regards,
Hirotaka Matsumoto
Matsumoto-san,
Could you share the datasheet for the crystal? I will follow up with the design team to see if they think a current limiting resistor is required.
The crystal connections that I have seen use symmetric capacitor values. Using 10pF and 12pF capacitors is not something I have seen before.
What are the conditions for the oscilloscope plot with RX_ER and RX_CLK? What is connected to the RX_ER pin?
Patrick
Hello Patrick san,
Thank you for your reply!
After we confirm crystal model with our customer tomorrow, we will inform you.
We will show you the circuit around DP83848, but this is the confidential data.
So we send your E-mail address directly, after we obtain permission(from our customer) to send you the data.
kind regards,
Hirotaka Matsumoto
Hello Patrick san,
We really appologize that our customer could solve this problem which RX_CLK stops oscillating.
As the result, it caused RESET_N.(The main CPU remains to output low to RESET_N.)
Kind regards,
Hirotaka Matsumoto
