Other Parts Discussed in Thread: AM4377, DP83822I, TLK105
Dear engineer;
Please help to analyze about the below question which is about TLK105L.
Problem:
[We have an EtherCAT board utilizing the Sitara AM4377. Our design was based on the AM437x Industrial DevKit for EtherCAT, so we are using the TLK105L as PHY device. We use 3 pcs of TLK105L: EtherCAT IN, EtherCAT OUT, and 10/100 LAN. We found out that if the board is in turned-off state (power is OFF) and LAN cable is connected to local LAN, our local LAN detected a loop connection. This is also true with the AM437x IDK. We change the PHY to other pin-compatible vendor and we didn't experience trouble just like TLK105L. Let us know if there are work around. Is this a known bug?]
Best regards
kailyn
