Hi team,
Can you please review the followings? In some test, it's confirmed that link is not recovered after inputting RESET_N. (At that time, phy register seems to show link up.). On the other hand, the link is recovered in case of global reset.
1. What is the difference between H/W reset and Global reset based on above result?
2. At H/W reset, why does the RGMII communication error happen? Does the default settings after reset work?
3. When DP83867 is resetted by some noise impact, is there any method that SoC can recognize the reset?
4. This issue can be caused by schematic error? (However, the same symptom is duplicated even for over 1us RESET_N)
Thanks and best Regards,
Sam Lee
