Hello Team,
One of my customer is looking for dimensions of DP83848K thermal pad. Can you please help with the same?
We are not able to find it in datasheet and packaging details.
Mahendra
Hello Team,
Mahendra
Correct document linked in last post.
Hello Rob,
This PDF doesn't specify size of thermal PAD. 4.5mm is marked as distance between two extreme pins. Can you please verify?
Mahendra
Hi Mahendra,
My apologies, that document did not contain the thermal pad info.
Please see the attached PDF for the thermal pad info and suggested PCB footprint.
