Other Parts Discussed in Thread: DP83822I
I know current drive type Ethernet PHY should connect the transformer center tap to VCC. But i see two different type connections with the TDx signals.
One is the TDx signals parallel connect to GND through resistor and capacitor, the other is the signal parallel connect to VCC through resistor.
Which one should i choose and why?
