DP83848Q-Q1: Packages on several EVMs
Part Number: DP83848Q-Q1
Other Parts Discussed in Thread: DP83848I-POE-EK, DP83848I-MAU-EK, DP83848M, DP83848J, DP83848C, DP83848T, DP83848K, DP83848I, DP83848LFQ, DP83848VYB, DP83848H, DP83848YB
[ DP83848 ] Packages on several EVMs
Can you help me to figure out which EVMs have which package mounted on it?
As far as I check, there are two different type of EVMs for DP83848 on TI.com.
DP83848I-POE-EK
PHYTER® Industrial Temperature Single Port 10 100 Mbs Ethernet Physical Layer Transceiver
www.ti.com/.../dp83848i-poe-ek
DP83848I-MAU-EK
www.ti.com/.../DP83848I-MAU-EK
However, it seems that there are four different combinations of EVM and packages on price book.
DP83848H-MAU-EK
DP83848I-MAU-EK/NOPB
DP83848I-POE-EK
DP83848K-MAU-EK
Does this correspond to each package options?
DP83848X Family (*= Not Recommended)
APN
Temp Range
MII/RMII +
PKG
LEDs
Extra
*DP83848M
0 to 70
MII/RMII
QFN40
1
25MHz Clock/Low Cost
DP83848J
2
Low Cost
DP83848C
MII/RMII/SNI
QFP48
3
25MHz Clock
*DP83848T
-40 to 85
MII/RMII
QFN40
1
25MHz Clock
DP83848K
2
DP83848I
MII/RMII/SNI
QFP48
3
25MHz Clock + JTAG
DP83848Q
-40 to 105
MII/RMII/SNI
QFN40
1
25MHz Clock
DP83848LFQ
QFN40
1
25MHz Clock
DP83848VYB
QFP48
3
JTAG
DP83848H
-40 to 125
MII/RMII
QFN40
1
25MHz Clock
DP83848YB
MII/RMII/SNI
QFP48
3
JTAG
I'm bit concerned that the BOM of MAU board says slightly different (really old info, though).
It's appreciated if you can double check.
Ken
