Other Parts Discussed in Thread: DP83867CS,
Hello
I have a question for RGMIICTL2 register of DP838767.
In the application note, “Latency in Factory Automation(SLA240)”, there is a description about Latency Configuration on P6.
In this section, it is said that RGMIICTL2 has bit 2 bit field, “LOW_LATENCY_10_100_EN”.
But this bit2 bit field is reserved on DP83867IR/CR on the datasheet, although DP83867CS/IS/E supports this bit field.
Isn’t this bit2 supported on DP83867IR/CR ?
Oba
